Page 1 of 3 1 2 3
Questions on this liftkit #740902 07/28/06 07:12 AM
3
355Camaro Offline OP
Was browsing some sites and saw this kit on autoanything.com 2" or 3" Body lift kit
I dunno usually how much these kits go for - but for $123 that doesnt seem too awful high to me, especially if it comes with all the extenders to re-align items. Ideas?
2000 Audi TT 1.8Turbo Quattro
1988 Chevy Camaro - 100% Built + for sale!
Re: Questions on this liftkit [Re: 355Camaro] #740903 07/28/06 09:52 AM
dewmtndew Offline
do yourself a favor and get a 4crawler kit. quality and incredible customer service.
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: Questions on this liftkit [Re: dewmtndew] #740904 07/28/06 01:14 PM
fourwd1 Offline
I second that <img src="/forums/images/graemlins/kewl.gif" alt="" />
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Questions on this liftkit [Re: 355Camaro] #740905 07/28/06 04:07 PM
DirtCheap Offline
I, recently purchased a "Performance Accessories" 2" lift for $110.00 from the local 4x4 shop and am real happy with it. It included all brackets, extensions, bolts, etc.. IMO the bodylifts are overpriced for what you get but at the time it was the quickest way to go.
1989 Toyota SR5 DLX SB
1995 Toy DX XTRA Cab 4x4
1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat
1988 Dodge Raider A/T w/Offroad Package
1959 Corvette
1977 Z28
1979 Honda CBX 1000 6 cyl
Re: Questions on this liftkit [Re: DirtCheap] #740906 07/28/06 05:53 PM
willzrunna96 Offline
i got my trailmaster 3" from autozone special order i paid 80 with emply discount but i think it retails for 90 there
Re: Questions on this liftkit [Re: DirtCheap] #740907 07/30/06 05:42 AM
dcg9381 Offline
I just happen to have a 3" PA kit for 86-88 4runners.. I'd sell it to a 4x4 wire member for 1/2 price.. still in the box. email me directly.
22REturbo.net
1988 4Runner
Re: Questions on this liftkit [Re: fourwd1] #740908 07/30/06 06:07 AM
abnormaltoy Offline
I 3rd that! Roger makes THE best BL I have seen...besides he's a good guy!
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: Questions on this liftkit [Re: abnormaltoy] #740909 07/30/06 08:33 AM
3
After doing my homework, Im thinking I might not even lift the body since it won't grant me any ground clearance. But I will browse Marlins site for a 2" Body lift to squeeze some 33's or 35's onto the yoter. Ground Clearance seems to be mainly what I need to try to gain at this point. When I finally got my truck stuck (mines the IFS setup, wish it was sas) the rear axle and the IFS center point got lodged on a nicely planted rut...
If I were wanting to get the middle section of the truck a little higher off the ground, what shocks/leafs would you all recommend? I've seen alot of you run "Rancho" shocks. Right now the truck has brand new Bilsteins on it and brand new stock leafs on it.
Some one with an 86 pickup is giving me his shocks/leafs but he said it's a 4" Lift. Will I have to mess w/ the drive shaft/E-Brake cable/ any other major component if I wanted to swap his components into my truck?
Re: Questions on this liftkit [Re: 355Camaro] #740910 07/30/06 10:59 AM
DRTDEVL Offline
No lift will net you ground clearance, period. Stock or 12" will have the same amount.
TIRES give you ground clearance.
The BL enables you to easily fit larger tires to gain ground clearance. Stock tires are about 28", and you can get 31's to fit stock. 32's can be had if you carefully select wheel/tire combo. A 3" BL enables you to run 33-35" tires, for a gain of 2.5-3" ground clearance.
What you are looking for is breakover angle. The best way to achieve this is a 3" BL and a 2" drivetrain lift. The frame is not your hanging point... Your crossmember is. Lifting the drivetrain 2" will give you a nearly flat underside, and the addidtional 2", for a total of 4.5-5" gain.
Check with 4Crawler... He can hook you up with all of this.
Re: Questions on this liftkit [Re: DRTDEVL] #740911 07/30/06 03:51 PM
Scerb Offline
Phrased this wrong.. No lift will give you AXLE clearance. Suspension lifts give you frame/crossmember clearance. Just wanted to clarify..
-Scerb
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6410 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-11-03 11:36:19 UTC
