howlin #741352 07/30/06 06:03 AM
salvo Offline OP
about a month ago i replaced the crush sleve and seal on my rear 3rd, it was fine before except for leaking oil, and it was fine up untill a few days ago... now under torque the rear seems to have a hummmm/howel to it? if im coasting it goes away? The gears were set up properly and backlash and all was good when i put it back in
Re: howlin [Re: salvo] #741353 07/30/06 09:50 AM
Brian894X4 Offline
I know that when my rear diff bearing went out, it made a very loud and noticable howling noise, only under load.
Sounds like you have a bearing problem of some kind. Either bad, or loose, dry, etc. Did you replace all the bearings? If not, that's probably what it is.
Re: howlin [Re: Brian894X4] #741354 07/30/06 05:01 PM
salvo Offline OP
thats what i was scared of.. well this will be the 4th time iv changged out the 3rd in the last 2 months due to my own stupidity
Re: howlin [Re: salvo] #741355 07/30/06 06:27 PM
Stevie Offline
No man; Belive me, you're smarter for it. We've ALL been there! <img src="/forums/images/graemlins/lol.gif" alt="" />
'80 4X4 Longbed
Re: howlin [Re: Stevie] #741356 07/31/06 02:42 AM
brentox Offline
I was dumb enough to pull my tranny and replace the input bearing thinking that was what the noise was <img src="/forums/images/graemlins/smile.gif" alt="" />. Swaped in some fresh 3rds and no more noise. Now that was stooopid!
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: howlin [Re: brentox] #741357 07/31/06 04:37 AM
salvo Offline OP
thats about what i pulled...lol... I originally swapped out the 3rd because their was a noise comming from the rear end. Put the other 3rd in and noise was still their... it turned out to be the dam ujoint... so i put a new crush and seal in teh original and put it back in ... guess i should have went the extra step and done bearings at the same time ...DOHHH
Re: howlin [Re: salvo] #741358 08/07/06 12:51 AM
salvo Offline OP
well found the problem after pulling the 3rd.... I guess the mecanic forgot to torque the bearing cap bolts after adjusting the end caps.... All 4 bearing cap bolts had backed out and the gears were just floating around in their .just being held in place by the axles. Needless to say the teeth are half chipped off now making the gears usless and left a big ding in the housing.. Just wait till i talk to the mecanic the next time i go to work... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: howlin [Re: salvo] #741359 08/07/06 06:24 AM
G
GOI87 Offline
Gotta' love someone else's stupidity at work. <img src="/forums/images/graemlins/baby.gif" alt="" />
At least you know it wasn't your falt <img src="/forums/images/graemlins/smile.gif" alt="" />
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: howlin [Re: GOI87] #741360 08/07/06 07:16 PM
salvo Offline OP
Well i can blam a little on me... I should have checked the tourq on all teh bolts before i put it back in... <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6261 MB (Peak: 0.7129 MB) Data Comp: Off Server Time: 2026-07-13 15:47:45 UTC
