22R top end ticking noise? #741693 08/01/06 02:08 AM
Just adjusted the valves about 1000kms ago and now my engine has a ticking noise comeing from the top end at about cyld. #2. Any ideas? I opened the cover and inspected the valve tain it seamed fine and check the clearences again but nothing was out. I know about 1 out of every 3 22R I hear drive by have a similar noise to them. Thoughts?
Re: 22R top end ticking noise? #741694 08/01/06 02:16 AM
kewlynx Offline
In most cases on the older mills, the valve adjustment screws have developed flat spots on the ends, and are no longer nice and convex.
You can rotate the cam around, just as you would for adjusting the valves, and remove the screw completely for inspection, reinstall and adjust; move on to the next.
Part number might be up in the part number sticky.
**ubi apis- ibi salus**
Re: 22R top end ticking noise? [Re: kewlynx] #741695 08/01/06 02:25 AM
BROWNBAGG Offline
adjust your valves 7- 11
Re: 22R top end ticking noise? [Re: BROWNBAGG] #741696 08/01/06 03:50 AM
I'm not sure I understand your last?
Re: 22R top end ticking noise? #741697 08/01/06 04:02 AM
kewlynx Offline
Instead of the spec .008 and .012 for the valve clearances, he suggests to tighten up to .007 and .011
Folks do it; doesn't always fix it.
Re: 22R top end ticking noise? [Re: kewlynx] #741698 08/02/06 03:08 PM
ToYPU Offline
I replaced my vavle adjustment screws and it helped my ticking then retorqued exhaust manifold and set the timing on the motor and it is not amost gone except for my 225k injectors ticking away lol they are not loud tho...
kevin <img src="/forums/images/graemlins/lol.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: 22R top end ticking noise? [Re: ToYPU] #741699 08/05/06 01:12 AM
F
fly_it_slow Offline
No way, I thought that was just me. My brand new engine ticks and I wasn't going to worry about it until 500 miles when I changed the oil after breaking in the rings.
I was at Wally's and a guy started up his 22r Toy and I said, wow, it sounds like you need a tune-up like I do. He said he had just had his engine rebuilt.
Do all the 22r engines tick like this?
Joa
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6114 MB (Peak: 0.6880 MB) Data Comp: Off Server Time: 2026-11-02 10:59:25 UTC
