My 99 TJ with the 4.0 and 5-speed will not go into gear while running. When engine is off, I can run the shifter through all the gear positions (3rd can be a little tight) but when engine is running I cannot move shifter into any gear position except revers it seems able to move to but grinds when I start to move shifter into reverse so I immediately revert to neutral. So I guess my clutch will not release. I don't notice any fluid leaks, it is a hydraulic clutch.
Looking on-line at some how-to sites about changing a clutch, I decided this job would be way over my head. And I don't even know enough to diagnose the problem --clutch or cylinders? So I had it towed to a transmission shop. I expect they'll call me this afternoon to tell me what I need. Do I trust him if he says I need a new clutch or doesn't this just sound like a master-slave cylinder problem? On the phone before I had it towed there he was saying maybe new clutch, but another shop with too long a wait list said sounds like slave or master cylinders.
So if it is cylinders, would you replace both together? Or just the one that failed. A friend advised that if one goes (say, the slave) then should also replace master because it will probably go soon after. Treat them like a unit, like we did when we put new universal joints on both ends of rear axle even though only one seemed bad?
Also, if I do need a new clutch, is it worth the extra money to get a heavy-duty clutch or is OEM good enough? On-line I found OEM clutches for about $180 and Centerforce Heavy Duty clutch (they say its 90% stronger than OEM) for about $305. And those are not necessarily the brand and prices my mechanic will offer but I cite them as probably low approximations of the price difference he'll probably offer me if I enquire about a heavy duty clutch.
I do take it off-road sometimes, through swampy mud and over rocks and steep hills. I don't know how much it affects the issue but I'll add that I have 31 x 10.50 mud tires on it and a 2" suspension lift. Except for a great LoD xtreme duty rear bumper with spare mount, the Jeep is otherwise stock.
