change diff gears or transfer case gears #742283 08/03/06 04:52 AM
I noticed that petroworks. com has a transfer case that changes the gear ratios as I would use with large tires (like 31"). I am used to changing the diff gears to acheive this. I assume that the torque on the drive train components will be harder using the t case gear set. Is it safe to do this? I am used to carrying spare axles, but would i also now need a spare drive train, etc?
Re: change diff gears or transfer case gears #742284 08/03/06 05:56 AM
Billjohn Offline
I carry a left and right front axle shaft in my spares box. If you carried an extra part for every upgrade, you wouldn't have room for the cooler (grin). I have both upgraded tcase gears and diff gears. Just do the math and figure which comes closer to what you need.
I would not go overboard with one without doing the other.
Bill
God Forgives, Rocks Don't...
Re: change diff gears or transfer case gears [Re: Billjohn] #742285 08/03/06 06:10 PM
blevcom21 Offline
i have stock t case and 4.56 in the diffs turning 32" rubber and that is fine for now but i want the 4:1 t-case gears i say get both start with diff gears they are cheaper
if it don't fit, force it if it breaks, it needed to be replaced anyway
Re: change diff gears or transfer case gears #742286 08/04/06 05:27 AM
Diff gears for now I say (and an ARB air locker). Anyways I had to rework the clutch and transmission. I should be done tomorrow.
Does anyone else rock left to right a good six inches at highway speed?
Re: change diff gears or transfer case gears #742287 08/04/06 01:59 PM
Billjohn Offline
Only when the wind gusts - or I'm getting passed by a Semi.
It also happens when one runs shackles that are too long...
Bill
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5983 MB (Peak: 0.6612 MB) Data Comp: Off Server Time: 2026-06-09 23:17:29 UTC
