Offenhauser on CJ5
#742408
08/03/06 08:16 PM
Ok I got a Holley 390 4bbl and a new Offenhauser single plane intake for my '80 CJ5 w/ '76 258. Well it pretty clear that I have to do something because the carb just bearly hits the brake booster. Now I have two options here loose the power brakes all together and go to manual or modify the bracket and push rod to shorten the whole thing about an inch or so to make clearence for the carb. So what I getting at is has anyone done this before or know of a place I can get good info on this I really don't want to mess this up.
Thanks
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Offenhauser on CJ5
[Re: mudslinger258]
#742409
08/03/06 08:50 PM
I think I have heard of guys grinding on the manifold to make it clear. Have you examined the possibility of doing something like that? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#742410
08/03/06 09:47 PM
You mean grinding the seating surface??? Not to sure if I like that idea, sounds like problems just waiting to happen. Any other options??
[Re: mudslinger258]
#742411
08/03/06 10:23 PM
No I mean grinding the small area that is touching the master cylinder.. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#742412
08/03/06 11:15 PM
Oh, I have heard about milling down the seating surface as well, but anyway its not the intake hitting the master cylinder its the upper corner of the carb where the diapham housing for the vaccum secondaries, is hitting the brake booster. Thats where the problem is, so I am looking at converting to manual brakes or modify the booster set up, but I am open to ideas. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: mudslinger258]
#742413
08/03/06 11:28 PM
Do you think you could get the linkage to work if you turned the carb backwards? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6075 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-06-17 10:29:45 UTCValid HTML 5 and Valid CSS
