Is there an altenator that will swap with my Tropper #742442 08/04/06 12:57 AM
Jayson1 Offline OP
87 Tropper II wondering if there is an altenator that will replace the the stock one. Not looking to do any fab work, if so I'll just replace the stock one. Jayson
87 Tropper II, Supewinch Hubs, First big 4x4 test: pulled a 84 Mercury out of a muddy ditch while in park.
Re: Is there an altenator that will swap with my Tropper [Re: Jayson1] #742443 08/04/06 01:14 AM
thepcguy Offline
Are you looking for a stock replacement or an upgrade?
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: Is there an altenator that will swap with my Tropper [Re: thepcguy] #742444 08/04/06 01:39 AM
Jayson1 Offline OP
An upgrade if possible. Jayson
Re: Is there an altenator that will swap with my Tropper [Re: Jayson1] #742445 08/04/06 04:50 AM
barak Offline
I put one in when I had my 89 with the 2.6.It was a 110 amp I believe , but it wasn't cheap.It cost me just over 300 CAN , but it bolted right in.The only thing I had to change was the bottom bolt that threadedinto the alt bracket was replaced with a regular nut and bolt.No big deal to change.You might have to go back about 2 years or so in my posts to get more specs on it like name and part #.I do know its in there somewhere in posts on alternator upgrades.It worked alot better than the stock , especialy if you have a winch , or even just a few lights and a big stereo <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6032 MB (Peak: 0.6582 MB) Data Comp: Off Server Time: 2026-06-07 09:41:36 UTC
