Wobbly CV Joint #742453 08/04/06 01:34 AM
creeve4 Offline OP
On my 94 4runner (4X4), I can move the outer CV joint by holding on to the CV Boot. I can move the CV joint about 1/8 of an inch in any direction expect in and out. When I am driving on anyhting but flat, smooth pavement, i can hear the Cv Joint rattle. Is the CV Joint bad? Could it be caused by loose or damaged bearings?
Thanks,
Christopher
Re: Wobbly CV Joint [Re: creeve4] #742454 08/04/06 04:34 AM
kewlynx Offline
Are the boots torn?
How does it compare to the other side?
The CV axle floats in there a little, as it goes straight thru the hub.
What caused you to crawl under there?
**ubi apis- ibi salus**
Re: Wobbly CV Joint [Re: kewlynx] #742455 08/04/06 05:35 AM
creeve4 Offline OP
The boot is fine. It moves much more than the other side. I climbed under to find the source of a rattle I've been hearing for the last week, and I believe it may be caused be the loose CV Joint.
Re: Wobbly CV Joint [Re: creeve4] #742456 08/04/06 05:56 AM
kewlynx Offline
If this is also on the passenger side, get a hold of the differential flange and see if it's still rigid or not. I had a carrier bearing fail once; that was fun. The flange shouldn't move.
http://www.4x4wire.com/toyota/maintenance/cv_axle/ <img src="/forums/images/graemlins/kewl.gif" alt="" />
If ya wind up changing it, try and take the axle to the parts store with you and save on the core charge up front-- was $90 about 2 years ago.
Re: Wobbly CV Joint [Re: kewlynx] #742457 08/09/06 01:40 AM
dknight Offline
Sounds to me like the spindle bushings are worn.
see
http://www.yotatech.com/~corey/tech/jimrockford_spindle/jimrockford.htm
For instructions on how to replace these bushings with bearings. For a short term fix you can put some grease between the CV shaft and spindle bushings.
Re: Wobbly CV Joint [Re: dknight] #742458 08/12/06 04:49 AM
TNToy Offline
For the past week? Do you make a habit of driving with your hubs locked all the time, or is it rattling while going over bumps?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6081 MB (Peak: 0.6781 MB) Data Comp: Off Server Time: 2026-05-29 17:53:19 UTC
