Remove the bump stops on the rear suspension? #742486 08/04/06 02:21 AM
Strider93 Offline OP
I have a 95.5 Rodeo. I have 255's on 16 inch wheels and am pretty happy with my ride height and ride, as the vehicle sees mostly highway miles. My only gripe is that the rear bump stops mounted to the frame seem to be too conservatively limiting the upward travel, and a couple of times on the highway with a load of people and gear I have hit the bump stops, on a paved road.
Has anyone removed these or made them smaller?
TIA
Re: Remove the bump stops on the rear suspension? [Re: Strider93] #742487 08/04/06 02:54 AM
9
94redrodeo Offline
mine has no bumps stops It seems fine without mine is soa though but I dont think they are neccesary
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Remove the bump stops on the rear suspension? [Re: Strider93] #742488 08/04/06 04:33 AM
Gizzy42 Offline
Trim them maybe, removing them is not a good idea. You will bottom out at some point and bust your shocks.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Remove the bump stops on the rear suspension? [Re: Gizzy42] #742489 08/04/06 05:12 AM
Jim_Paget Offline
I have broken two shocks (OME) by not having bumpstops.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Remove the bump stops on the rear suspension? [Re: Strider93] #742490 08/04/06 05:34 AM
randii Offline
Stockish or 1-3" lift, definitely keep them... as you lift the truck beyond that, they are potentially less necessary on the street, as you'll hardly be able to touch them. Off-road, they are even more important, in that they prevent inversion, but as you lift even beyond 6", it becomes harder to touch them -- but when you do, muy importente!
If you have good enough springs to flex to extremes, bump stops are critical... most folks simply don't get enough flex to benefit from bump stops on high-lift trucks, unless they resposition the bumpstops lower...
Note that your bumpstops may also protect your exhaust and shocks from getting smashed/broken.
Randii
Re: Remove the bump stops on the rear suspension? [Re: Strider93] #742491 08/04/06 06:29 PM
Paddler Offline
TIA
If you have a 3" body lift, you can take out the 2" spacer and you will gain a lot of flex with an ever so slight rubbing at full flex. If you don't have the BL you're going to tear things up.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Remove the bump stops on the rear suspension? [Re: Paddler] #742492 08/07/06 07:10 AM
Thanks for the replys all... I don't have either a body lift or any lift on the rear springs. Actually I would like to research doing a mild lift on the rear, say 2 - 3 inches max. It seems like the rear sits lower than the front when I am packed up for a trip: 4 passengers, dog in the back, all the gear on top... even worse when towing my tent trailer.
But those bump stops only seem to allow only 2 - 3 inches of travel, and I'm pretty sure there should be more... The rear end doesn't seem to be sagging anymore than the first day we bought it new.
I think I'll try trimming an inch off of them, then explore options to lift the rear a couple of inches.
Thanks
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6159 MB (Peak: 0.7063 MB) Data Comp: Off Server Time: 2026-10-26 02:29:02 UTC
