speedometer cable #742545 08/04/06 06:44 AM
L
lostone Offline OP
my crossover pipe for my headders came loose and burned a hole in my speedo cable causing it to come apart. where can I get a new cable and housing assembly?
second, where is the fill plug on the r150 transmission?
Re: speedometer cable [Re: lostone] #742546 08/04/06 07:42 AM
kewlynx Offline
www.1sttoyotaparts.com stuff in red-n-white boxes
www.car-part.com junkyardin'
**ubi apis- ibi salus**
Re: speedometer cable [Re: lostone] #742547 08/04/06 01:19 PM
1
10_35lookoutbelow Offline
It is on the drivers side of the transmission, drain is on the passenger side.
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
Re: speedometer cable [Re: 10_35lookoutbelow] #742548 08/07/06 01:27 AM
toyotaguy55 Offline
the fill location will be a ***** to get to without a poer filler so i pull the fill plug and thenpull the shifters and slowly add fluid utill it drips out the fill plug hole <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
Re: speedometer cable [Re: toyotaguy55] #742549 08/07/06 02:42 AM
G
GreyDuck Offline
I've used a little drill pump like this one to fill my W56 tranny and it worked well. I bought mine a Menards for about $4 if I remember correctly and I got some poly tubing that fits tightly into the in/out holes on the pump.
http://www.hardwarestore.com/pop-print/larger-image.aspx?prodNo=2037
1990 Truck 4X4 5sp 22re
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6044 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-11-04 15:48:15 UTC
