Leaking fuel tank? #742574 08/04/06 01:18 PM
1
10_35lookoutbelow Offline OP
Just a quick Q
I filled up on petrol last night and when I got to work this morning I noticed a fuel smell, so I checked out the tank and found a little bit of seepage coming from the filler pipe attachment point at the tank. Could this leakage be just because the tank is full (normal) or am I looking at a bigger problem with rust on the tank around the filler pipe? The tank is covered with dirt now but I will check into it further by cleaning the area with a wire brush and looking with a flash light.
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
Re: Leaking fuel tank? [Re: 10_35lookoutbelow] #742575 08/04/06 02:18 PM
fourwd1 Offline
It's quite possible it's leaking due to rust, I had that problem on my Maxima. Could also be a loose hose clamp.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Leaking fuel tank? [Re: 10_35lookoutbelow] #742576 08/04/06 02:25 PM
go_big_blue Offline
I had to replace the fuel pump bracket. The 3 lines coming out of it were rusted through. Had to get it at the dealership, think it was about $130. It was easier to raise the bed rather than drop the tank. I took the bolts loose and jacked it up about a foot and put some blocks under to hold it up.
1991 4wd Toyota 22re, 1.5" ball joint spacers, 1" body lift, 33 Baja Claws, Aussie locker, Budbuilt crossmember w/ 1" drivetrain lift
Re: Leaking fuel tank? [Re: go_big_blue] #742577 08/04/06 05:55 PM
fourwd1 Offline
That also is a common problem, but he's talking about the filler neck. And raising the bed is easier (usually) than dropping the tank, especially if it's full.
Re: Leaking fuel tank? [Re: go_big_blue] #742578 08/04/06 07:36 PM
about having to replace a leaking fuel sending unit.....screw that man way too expensive....you can drill out the old pipes and either weld/braze in new fuel lines as long as you make the rights bends in the new pipes.....just make sure to test it with pressure before reinstalling it to make sure you didn't burn any holes into the new pipes.
Re: Leaking fuel tank? #742579 08/04/06 07:50 PM
ToyotaT Offline
This happened to my lines after I took the bed off a couple times. I hate to admit it, but I was too cheap to pay the $tealer the above mentioned price. I went to Farm and Fleet and bought some hose and hose clamps and fixed the leak with them.
I initially meant it as a temp fix until I found a cheaper source for the lines, but time has gotten away from me. I think that's been almost two years ago. Yes, I should replace it.....
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: Leaking fuel tank? [Re: 10_35lookoutbelow] #742580 08/05/06 08:58 AM
Davepet Offline
It shouldn't leak at that point, even with a full tank. While it might be a rust problem, I'd be inclined to check the clamp on that filler hose first.
Of course if you need to disconnect that hose to check further, be sure to get rid of any dirt in the area first. An open fuel tank filler seems to have a magnetic attraction to any debris within 3' of it <img src="/forums/images/graemlins/wink.gif" alt="" />
Dave
Re: Leaking fuel tank? [Re: 10_35lookoutbelow] #742581 08/05/06 09:47 PM
ACES_HI Offline
Yup, rust is your enemy when it comes to fuel tanks. Find the source of the leak. It is likely coming from the sending unit on top of the tank. If it is you WILL snap bolts off from the skid plate and tank trying to drop the tank to replace the sending unit no matter how much you spray them (even with Silikroil). EFI is a biatch because its a high pressure system and when you have a leak you have a geyser!I never tried raising the bed to remedy the problem. Took it to the stealership and said fixit. Took two fire extinguishers for that ride since I had gas spraying everywhere! <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" /> For leaks in the tank itself, JB Weld works wonders!
Wow post 420 (4:20)! <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Leaking fuel tank? [Re: ACES_HI] #742582 08/08/06 01:31 PM
1
Yeah Boys sorry to confuse you, but I meant that the problem was at the filler, and not the sending unit (replaced it before, yep its a bugger just for that little pipe on top rusting out!) SMEAR THE SENDER TOP WITH A FAT PAW A GREESE!!!
Anyway I took off the filler hoses and found that rust had gotten under the rubber hoses. Cleaned them by scraping with a screwdriver and then wire brushing, thank god I have a BL. then I smeared some grease on the tank and reinstalled the hoses. It was a bit of a PITA to stretch the hoses back on and tighten the clamp at the same time! Hopefully I got it on far enough to make a good seal. But I'll see when I fill up the tank next!
Good show ACES_HI <img src="/forums/images/graemlins/shiner.gif" alt="" />
Thanks for the help!!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.005s) Memory: 0.6292 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-10-24 02:37:11 UTC
