95 sr transmission problem
#742688
08/05/06 09:35 AM
here's the situation. whenever i put the gear selector in reverse position the dash board light (that little r between p and n) doesn't light up. it lights up just before and after as i slide the selector lever. the reverse works, but there's no backup lights. any ideas? could this be the selector switch inside the transmission? if so, can i clean it, or do i have to get a new one? thanks
Re: 95 sr transmission problem
[Re: jaco]
#742689
08/06/06 10:13 AM
It certainly sounds like your inhibitor switch is the problem. I've never had this on my Montero but I have had the same problem on a Toyo. It looks like the Reverse contact is the first to go, maybe because you always have to pass through R to get to the other gears. I think your switch is located on the outside of the trans?? I also don't think there is any way you can disassemble and clean it. What I did is check my adjustments and try to postion the switch to pick-up the reverse contacts. Having a helper in the vehicle to move the shifter and observe the lights makes it way easier. So far my adjustments have worked. These switches are expensive to buy new so getting more miles from it makes sense.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5888 MB (Peak: 0.6369 MB) Data Comp: Off Server Time: 2026-06-20 22:18:49 UTCValid HTML 5 and Valid CSS
