Re: My 7M-gte build [Re: 1986xtracab] #742776 08/08/06 01:03 AM
CJM Offline OP
thank you ! smile
more progress today .
MLS head gasket in place , and new ARP head studs .
and the head goes on , and torqued to 80FT lbs
back cover and set the valve covers on for effect .
and almost done ...
83 Trekker SR5
NEW Trekker forum
Re: My 7M-gte build [Re: CJM] #742777 08/08/06 02:01 AM
1
1986xtracab Offline
The more pictures of this I see the more I think about spending some of my school financial aid and buying a master rebuild kit from EB! <img src="/forums/images/graemlins/smile.gif" alt="" /> .....but I guess it will have to wait a bit longer.
Re: My 7M-gte build [Re: 1986xtracab] #742778 08/08/06 05:34 AM
anthony1 Offline
Looks great! now you can put it in my 89 supra...... <img src="/forums/images/graemlins/notooth.gif" alt="" />
Hope the oil filter doesnt line up with anything underneath.
It's a mess to get it out in the supra.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: My 7M-gte build [Re: anthony1] #742779 08/09/06 01:24 AM
CJM Offline OP
yeah .. anything is possable ,for the right amount of cash smile
I had a oil filter "relocation" kit .. but I sent it back .. I'm gonna wait til I get the frame done , and go from there .
83 Trekker SR5
NEW Trekker forum
Re: My 7M-gte build [Re: CJM] #742780 08/13/06 05:20 AM
CJM Offline OP
did a little more today ...
got the valves adjusted , and cams in
and bolted on the covers , new thermo , cam seals ......
also started on the RC - 550's
400 Horses , here I come
83 Trekker SR5
NEW Trekker forum
Re: My 7M-gte build [Re: CJM] #742781 08/14/06 02:39 AM
CJM Offline OP
so .. more .. ;D
fuel rail is buttoned up , and also center gasket
timing gears are installed "correctly" and belt installed .
also thermo housing .
exhaust manifold , and shields .
front cover
and the upper intake ..
just about done .
83 Trekker SR5
NEW Trekker forum
Re: My 7M-gte build [Re: CJM] #742782 08/14/06 03:13 AM
trythis Offline
I was expecting some kind of fancy header, instead of the standard manifold. I am not unhappy, just surprised. I really would like to see how this fits into the same space a 22re fits.
How much would a guy expect to pay to do something like this, assuming the block is used. Looks like a really nice setup. Thanks for taking pictures. Have you done this before?
Re: My 7M-gte build [Re: trythis] #742783 08/14/06 03:35 AM
CJM Offline OP
I'm expecting 350-400 hp with this set up . Stock manifold is excellent . custom would net more , but i'm NOT sure I need more ????
I'm gonna "cheat" ... I'm doing firewall and tranny tunnel mods to get it where i want it smile
Yes , I have been "in the business" for 27 years .. I've done more then I can count > off hand .
cost wise , I have about 4G's into it + my time ( little more then a 100 hours so far)
83 Trekker SR5
NEW Trekker forum
Re: My 7M-gte build [Re: CJM] #742784 08/15/06 07:25 PM
4
4runner4ever Offline
The oilfilter should fit just fine. And it's easy to replace.
Atleast it is on mine.
My engine fits without firewall mods. Except for a BFH that is.
Nice job. Why did you go for the 7M-GTE plus rebuild and not a 2JZ-GTE?
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: My 7M-gte build [Re: 4runner4ever] #742785 08/16/06 01:43 AM
CJM Offline OP
I opt for the 7M-GTE , because it came with the car smile
The little (as I like to call it) "HOTROD" its going into , will also have the supra suspension .. front and rear .
I picked up the car fairly reasonably ... which I couldnt say for a 2JZ supra .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6475 MB (Peak: 0.7721 MB) Data Comp: Off Server Time: 2026-11-02 08:27:53 UTC
