Threadlocker #742885 08/06/06 11:41 PM
bodo Offline OP
When you rebuild your 22re motors where do you use threadlocker or antisieze? I always told to put threadlocker on headbolts but the toyota, chilton, and haynes manuals don't mention it.
Re: Threadlocker [Re: bodo] #742886 08/07/06 03:59 AM
salvo Offline
put it on anybolts that you do not want to move.
Re: Threadlocker [Re: bodo] #742887 08/07/06 09:03 PM
Stevie Offline
Red, or Blue?
'80 4X4 Longbed
Re: Threadlocker [Re: bodo] #742888 08/07/06 10:40 PM
P
poolville02 Offline
No threadlocker required on any of the engine fastners if their torqued properly. I used anti-seize on all of the bolts that thread directly into aluminum such as the oil pump bolts that thread into the timing cover. Dont forget the sealant on the top oil pump bolt so it doesnt leak oil. I also used the included anti-seize stuff on the headbolts that came with my engnbldr kit.
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5987 MB (Peak: 0.6534 MB) Data Comp: Off Server Time: 2026-07-14 12:26:03 UTC
