95 rodeo 4x4 engine conversion #742955 08/07/06 05:54 AM
tinytrooper Offline OP
I have used search feature thank you, I have 95 rodeo ticking like hell and wish to junk engine. What swap options are out there...Like the 3.4 swap for 1st gen troopers so forth....thanx for the replys oh yea its a 5spd
Re: 95 rodeo 4x4 engine conversion [Re: tinytrooper] #742956 08/07/06 06:54 AM
mlclark Offline
Isuzu Moderator
There are a few reasons that these engines tick. Usually, it is not a sign of impending demise.
#1 is the timing tensioner. Many a mechanic would diagnose a rod bearing for the sound, but it is the tensioner.
#2 if it is just a lighter tick, it is probably the way the oil flows through the upper end of the valve train. Common, no real damage, but there are several methods of dealing with or treating it.
Either #1 or #2 can be found by searching. It may save you the headache (and cost) of an engine swap.
Michael
Re: 95 rodeo 4x4 engine conversion [Re: mlclark] #742957 08/07/06 07:00 PM
I have used search feature as stated, the timing belt tensioner has been replaced along with belt. This truck has over 275k on the clock, and I'm looking for swap idea's. The ticking has been diagnosed but I do not wish to repair this engine. I haven't seen much talk of a rodeo engine swap. The reason for the post thnx, any idea's??????
Re: 95 rodeo 4x4 engine conversion [Re: tinytrooper] #742958 08/07/06 07:58 PM
mlclark Offline
Isuzu Moderator
The reason there is no talk is because there is no easy swap out there (i.e. 2.8/3.1-->3.4). I believe you might get one of the versions of the Caddy northstar to bolt up to your tranny, but...you will need all that comes along with it. Engine mounts, cooling, computer, plumbing ect.
If you are bent on not going with another 3.2 or fixing yours, you would be better off swapping the entire drivetrain. If you go that route, all options are open. Pick an engine you like or are framilar with and pick a tranny/x-fer with a passenger side drop. Make the mounts, plumb the works and call it good.
Michael
Re: 95 rodeo 4x4 engine conversion [Re: mlclark] #742959 08/07/06 08:27 PM
Smiley Offline
MichaelÆs rightà
If an æeasy-to-swapÆ candidate existed, there would undoubtedly already be a Sticky at the top of the Isuzu Tech Page entitled ôReplace your tired-old 3.2s & 3.5s with a _______ !!!ö - Unfortunately, so far as anyone knows, thereÆs just no such animal. <img src="/forums/images/graemlins/frown.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: 95 rodeo 4x4 engine conversion [Re: Smiley] #742960 08/07/06 09:13 PM
9
94redrodeo Offline
A 3.4 would be a waste of time.
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: 95 rodeo 4x4 engine conversion [Re: 94redrodeo] #742961 08/08/06 12:35 AM
Thank you for the replys, I am not considering the 3.4, just using its ease as a reference. I would consider the cadillac northstar. Where is the information on the tranny bolt up, and expected life span? Is there a diesel alternative?....thnx
Re: 95 rodeo 4x4 engine conversion [Re: tinytrooper] #742962 08/08/06 02:32 AM
mlclark Offline
Isuzu Moderator
Apparently, the above was not quite clear enough.
You are on your own for almost anything you choose. There are no "alternatives" or other "options." You are breaking ground with whatever you choose.
There is limited talk about the Caddy motors. Search here, search Planet Isuzoo, search the Internet. You might find some references, but it has been done only a couple of times, that I know of. At least once, but less than 5 times, IIRC. My memory is not the end all answer, but I recall very little "How To" in the collective memory/intelligence of the Isuzu internet community.
Outside of that, anything you choose is totally custom. Ground up, like any other full engine/tranny swap. You can pull information from anywhere that has engine swap experience, but in the end, you will have to bolt it in, fab up what is needed and work out the bugs unique to your vehicle.
I wish you luck, but the road you desire is not an "easy" one.
Michael
Re: 95 rodeo 4x4 engine conversion [Re: mlclark] #742963 08/08/06 02:41 AM
9
94redrodeo Offline
Cadillac engines have very short life expectancy they rot the aluminum and you get holes in the block.
Re: 95 rodeo 4x4 engine conversion [Re: 94redrodeo] #742964 08/08/06 03:23 AM
mlclark Offline
Isuzu Moderator
Got reference and/or citation?
Michael
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-05-29 16:13:49 UTC
