spark plug gap #743085 08/07/06 07:33 PM
4
4mudder Offline OP
Anyone know the correct spark plug gap for a 89 K5 blazer 4x4 with a 350? thanks in adavance
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: spark plug gap [Re: 4mudder] #743086 08/08/06 04:32 AM
52degrees Offline
If the emissions sticker doesn't tell you, then go for .040 for standard plugs, .060 for platinums.
And for the sake of all sanity and all that is holy, use only ACDelco platinums. NGK and Denso's are ok too. Same for standard plugs.
Bosch platinums and GM engines don't mix <img src="/forums/images/graemlins/shame.gif" alt="" />
KG6VNX
Re: spark plug gap [Re: 52degrees] #743087 08/09/06 04:16 PM
4
4mudder Offline OP
I found the sticker it says .035. Thanks for the tip on bosch plugs. too bad i already bought them before my post. they seem great....for now.
Re: spark plug gap [Re: 4mudder] #743088 08/10/06 02:09 AM
52degrees Offline
Ick! Sorry. Maybe you won't notice any problems.
You will, but we can hope, right?
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5996 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-10-21 19:12:40 UTC
