fuel filter replacement #743227 08/08/06 06:47 AM
dailyDriver Offline OP
What's the easiest way to replace the fuel filter on my EFI 22re if I think this may be robbing me of power and mpg? Are there any tricks?
DailyDriver: '94 Xcab 4x4, 22RE, 139K miles, STOCK
Re: fuel filter replacement [Re: dailyDriver] #743228 08/08/06 06:50 AM
kewlynx Offline
PB Blaster (NAPA) the fittings before you start; do not unbolt filter until after you've taken the lines off.
Article is for the 3.0, but is basically the same procedure.
Linky
If the filter hasn't been changed that you know of, it's a good place to start, if you haven't done any periodic or preventative maintenance.
**ubi apis- ibi salus**
Re: fuel filter replacement [Re: kewlynx] #743229 08/08/06 02:23 PM
TexJeff87 Offline
Go in thru the wheel well. It's hard. You will scrape your knuckles.
Be really careful with the fuel lines. And make sure you put the banjo fitting warshers ( ha, warshers...) back exactly like they came off, or it will leak. Leak = bad....
If Mad Max had a 4runner...
Re: fuel filter replacement [Re: TexJeff87] #743230 08/08/06 03:12 PM
RatLabGuy Offline
If you remove the starter it will give you more room. Definitely go in though the wheel well, and I'd even go ahead and take the tire off just so you have some more room to fit yer body in there.
And yes prepare for scraped knuckles.
Question Reality.
Re: fuel filter replacement [Re: RatLabGuy] #743231 08/08/06 03:48 PM
1
1986xtracab Offline
after you do it you could also consider relocating it, I saw a picture yesterday where some guy had re mounted his on the passenger side wheel well in the engine compartment.
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.020s) Memory: 0.6079 MB (Peak: 0.6725 MB) Data Comp: Off Server Time: 2026-11-19 23:55:18 UTC
