NP231 transfer case--a few questions... #743261 08/08/06 03:13 PM
E
EricsTJ Offline OP
Hey Guys--I came over to the Jeep side--sold my Troopers that are in the sig line--trying to change my screen name, but can't seem to make that happen...Anyway,
when I came back from wheelin' the other day, there was a strange squeeking sound which I narrowed down to the front universal joint--specifically the "cup-like"(sorry!) attachment between the U-joints on the transfer case side.
I lubricated them with white lithium, and that has worked fine so far.But when I turned the yoke(on the t-case) by hand it seemed kind of rough--maybe the output shaft bearing? Is this normal?-Is it a function of the chain turning the input gears?
I know the answer to this next question ,BUT I have to ask--Can the output bearing be removed and replaced without dis- assembling the Transfer case? Please go easy on me, I'm just asking!I know that normally they are "pushed" out from the other side....Thanks guys in advance, any help would be appreciated..
BTW--'97 Wrangler TJ 5 speed 4 cyl 4x4.... <img src="/forums/images/graemlins/pfft.gif" alt="" />
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: NP231 transfer case--a few questions... [Re: EricsTJ] #743262 08/08/06 05:08 PM
I believe it is held in by a snap ring from the inside of the t-case, not pressed in. Luckily, the 231 isn't that difficult of a case to open up, the only special tool needed is a pair of snap ring pliers.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5871 MB (Peak: 0.6370 MB) Data Comp: Off Server Time: 2026-11-03 12:28:29 UTC
