Howell TBI, Best Investment #743439 08/08/06 10:48 PM
RLBomber Offline OP
Honestly, I finished installing the Howell TBI and she started right up and idled beautifully. Never had to any adjustments and she runs great. The acceleration is unbievable and even runs quieter.
This was done on a 89 YJ with a 4.2, 5 speed. The worst part about it was that I just installed a new rebuilt carb and a new ecm. But, these never fixed the issues the mechanics stated it would.
So, if anyone is interested in making an offer on these to items, I'll be glad to part with them.
Re: Howell TBI, Best Investment [Re: RLBomber] #743440 08/08/06 11:30 PM
BigJim Offline
Howdy RLB
You did do the nutter didn't you? She should run retarded and maybe hot if you didn't.
Re: Howell TBI, Best Investment [Re: BigJim] #743441 08/09/06 12:45 AM
RLBomber Offline OP
Big Jim, that's all part of the installation. They provided a new ecm that by passed the ignition module.
There was no other adjustment necessary. But I will tell you that it's a pain in the ass to put all those wires back in the harness.
Re: Howell TBI, Best Investment [Re: RLBomber] #743442 08/09/06 02:28 AM
BigJim Offline
That is a gooder deal.
Re: Howell TBI, Best Investment [Re: RLBomber] #743443 08/09/06 07:01 AM
Correction: The ECM provided bypassed the computer controlled carburetor. The ignition module is still in the equation.
Re: Howell TBI, Best Investment #743444 08/09/06 04:15 PM
BigJim Offline
Well hell! RL you need to check the timing real good ar several rpm to see what is happening. If you do not get all the timing you need then do the nutter and it WILL run better. I might just go ahead and do it anyway to make sure.. No! Scratch that... I WOULD do the nutter anyway! Then I would KNOW I had it running at it's best.
Re: Howell TBI, Best Investment [Re: BigJim] #743445 08/11/06 05:49 AM
The Nutter bypass is bypassing the ECM for the stepper motor and pulling the ignition module out of the ECM's feedback loop, correct??
With Howell EFI that ECM is removed from the equation altogether. It isn't physically there to bypass any longer, therefore the Nutter bypass isn't applicable. It's in effect already done. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Howell TBI, Best Investment #743446 08/11/06 06:18 AM
BigJim Offline
CSp you are totally WRONG! The nutter bypases the computer to the dist... Makes the dist respond like it should without the stepper motor carb..
Re: Howell TBI, Best Investment [Re: BigJim] #743447 08/11/06 06:57 AM
BJ, you just paraphrased what CSP said in less technical terms. In essence the howell "nutters" it as part of the modification.
Re: Howell TBI, Best Investment #743448 08/11/06 02:47 PM
BigJim Offline
So the kit furnishes components to do job as it needs to ne done? I'll accept that.
No matter how it gets done the dist needed to be turned loose somehow.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6362 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-11-19 05:32:37 UTC
