22 RE fuel pump longevity? #744320 08/13/06 06:32 PM
P
Pluton Offline OP
I've got a '91 22RE truck w/ 190K+ miles on it... does anyone know what the typical life of the in-tank fuel pump on these trucks is? Has anyone had a fuel pump "die of old age"? I just don't want to get stranded way far out...
Thanks, -Keith B.-
Re: 22 RE fuel pump longevity? [Re: Pluton] #744321 08/13/06 06:35 PM
4Crawler Offline
I thnk the one in my '85 is original, nearly 280K miles and pressure is still good. I do carry a spare in my parts box just in case. I thnk they last a long time as long as you don't run them dry too many times. That is probably the biggest killer, the pump uses the gas as a coolant and lubricant.
Re: 22 RE fuel pump longevity? [Re: 4Crawler] #744322 08/14/06 06:40 AM
P
Pluton Offline OP
Carrying a spare is probably a good idea..thanks. -KB-
Re: 22 RE fuel pump longevity? [Re: Pluton] #744323 08/14/06 07:36 AM
Brian894X4 Offline
It's a VERY good question and one that I've asked here a few times. Seems that they do typically last well into the 200K range.
I, like you, don't want to end stranded somewhere and even with a spare...which I do carry...it would be one heck of a PITA to change in the back country.
The only reason I haven't put a new one is that they're pretty spendy at Toyota...and I hate to go to all that work to replace it only to have to made some minor mistake or whatever to cause the new pump to fail or if I got a bad new pump.
I have well over 210K miles on my truck and I think I will eventually just replace the pump, but not right now. Maybe for next summer.
But as long as we're on the subject, I too, would like to hear more stories from others about how long they typically last and what were the signs of impending failure?
Re: 22 RE fuel pump longevity? [Re: Brian894X4] #744324 08/14/06 02:12 PM
ZUK Offline
I bet the FP would really like 4~8 oz of Marvel Mystery Oil evry fill-up....."top oil lubricant".
mostly stock
Re: 22 RE fuel pump longevity? [Re: Brian894X4] #744325 08/14/06 02:21 PM
4Crawler Offline
Piece of cake to change in a 1st gen 4Runner, access hatch under the rear seat bottom, right over the fuel pump. I just carry a used pump for a spare.
Re: 22 RE fuel pump longevity? [Re: 4Crawler] #744326 08/14/06 09:02 PM
dcg9381 Offline
Anyone know what volume the stock pump is rated for? IE - I want to know how much HP the pump will support.
22REturbo.net
1988 4Runner
Re: 22 RE fuel pump longevity? [Re: dcg9381] #744327 08/14/06 09:18 PM
4Crawler Offline
Not sure, but I think Mosk is pushing 200HP+ with the stock fuel pump.
Re: 22 RE fuel pump longevity? [Re: Pluton] #744328 08/14/06 09:41 PM
kens Offline
Fuel pump longevity û I thought it was around 280k for my 85 4runner. But this turned out to be not true. I broke down coming out of Saline Valley Rd (South Way). I got my brother to tow me home to San Diego. I narrowed the problem down to no fuel - via the access hatch under the rear seat û loosen the fuel line and no fuel. Went to the dealer pick up a fuel pump. I went to replace the fuel pump and the pipe was separate at the top of the access point (inside the gas tank). Returned the fuel pump and bought a new access point /fuel pump holder. Keep in mind that there is a long one and a short one. I learned this the hard way as well. So, to make a long story short I donÆt knowà
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6320 MB (Peak: 0.7350 MB) Data Comp: Off Server Time: 2026-11-16 01:31:59 UTC
