3.4L Gas Mileage????? #744928 08/15/06 10:17 PM
Kapuna Offline OP
Hi Guys....
Really like the BB...lotsa good info....
Anyways....recently bought a 1995 T100 2WD Ext Cab DX...131K...one owner (an engineer who doted on it)....
All maintenance has been done to specs...oil changes every 3K...timing belt...water pump...etc......
Main question is:
I drive mostly highway miles, so I slowed to 60 MPH as I have more time than money (i.e. no hurry), and my gas mileage has dropped to 19-20 MPG.
At 65-70 MPH, my MPG seemed higher at 21-23. <img src="/forums/images/graemlins/confused.gif" alt="" />
Is this possible????
Is my T100 more efficient at 65-70 MPH????
Any opinions are appreciated..
Kapuna (Hawaiian for "old dude")
Re: 3.4L Gas Mileage????? [Re: Kapuna] #744929 08/16/06 01:28 AM
E
elnido Offline
me too. It seems like 70mph is the sweet spot. I get my best milage when I'm really pushing it sometimes, makes no sense at all. I've even been leaving the O/D off. When I get back to nursing it, milage turns to crap.
Re: 3.4L Gas Mileage????? [Re: Kapuna] #744930 08/16/06 04:13 PM
jmoser Offline
Best I ever got was 19+ at 60-70 mph range. This includes camper shell and 31" tires.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: 3.4L Gas Mileage????? [Re: Kapuna] #744931 08/16/06 04:29 PM
foxtrapper Offline
Not disputing you, simply noting that my results are different. At 65mph I get 19mpg. At 70mph I get 17mpg.
There's hardly any deviation from those values, which I find interesting. I've never run across a vehicle that was so rock steady on its gas mileage as this truck is.
'97 T-100 SR5
Re: 3.4L Gas Mileage????? [Re: foxtrapper] #744932 08/16/06 06:25 PM
mrvoodoodaddy69 Offline
i get just over 19 myself. mix of driving but very consistant. i think it's a toyota thing. i had a 85 pick-up 4x4 got right at 20, didn't make a difeerence what i did, loaded-empty, fast-slow,big tires-stock tires, 20 wa what you could count on.
Re: 3.4L Gas Mileage????? [Re: mrvoodoodaddy69] #744933 08/16/06 06:50 PM
jmoser Offline
When I installed the massive TJM bull bar I lost mpg over 70 mph. That thing is just NOT aerodynamic!. <img src="/forums/images/graemlins/zombie.gif" alt="" />
I can say I get the same mpg with an empty bed or 1200 lbs of gear, also run 32 psi front and 37 rear.
Jeff
Re: 3.4L Gas Mileage????? [Re: foxtrapper] #744934 08/16/06 10:51 PM
Kapuna Offline OP
As stated earlier, this a 2WD model and I'm running street/highway tires. At 70 MPH, I'm turning around 2450 RPM with a 3.77 gear.
The only thing different I have done was add the surf racks that span the tonneau cover. Surely they would not cause that much wind resistance.
I'll keep checking that MPG...just trying to get all I can at today's gas prices.
This is my first Toyota and just love the quality they built into this T100.....
Thanks for all the info, guys....
Kapuna
Re: 3.4L Gas Mileage????? [Re: Kapuna] #744935 08/17/06 01:24 PM
jmoser Offline
At 131K you may be seeing some mpg loss due to drift on the O2 sensor.
Not cost effective to get back 1 mpg.
Jeff
Re: 3.4L Gas Mileage????? [Re: jmoser] #744936 08/17/06 06:59 PM
MR24Shoe Offline
I used to "putz around" at the speed limit for gas mileage purposes using cruise control.
Then I had a week where the cruise control didn't work, so I did things manually, and found myself in the 70 mph range.
I too noticed better mileage at the higher speed w/o cruise control. Couple things I attributed it to: drafting, and cruise control being too aggressive when going up hill.
Re: 3.4L Gas Mileage????? [Re: MR24Shoe] #744937 08/17/06 11:23 PM
dogslovetrucks Offline
I have been pondering the sweet spot for a while too.
I know my mileage plummets over 80mph, and is ok around 60, but set the cruise at 75 I will be getting 19, (with cap and 4wd) I think that the engine has a real easy time turning 3000rpm, and that wind resistance still is not so bad that it is eating up all of the power. I believe wind resistance goes up logarithmically (by the square of the speed) so at 20 mph wind resistance is 400, 40 mph it is 1600 and at70 it is 4900 and at 80 it is 6400 (I havent a clue about the unit) so a small increase in speed could be a massive increase in drag.....
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-17 03:22:29 UTC
