Where to get cats for '99 CA #744986 08/15/06 11:25 PM
larsdennert Offline OP
My computer keeps tripping the 420 code (catalytic system efficiency below threshold. It tripped it years ago on a trip to Mexico and I must have gotten some Leaded gas. Then it would only trip when driving offroad slowly. No it basically stays lit after the third cat test cycle. The stealer wants $820 for one cat. I was thinking to replace both. There are some on the net for ~$220. Some say with CA emissions -Exc CA. Pretty confusing...
Anybody bought one somewhere?
Re: Where to get cats for '99 CA [Re: larsdennert] #744987 08/16/06 06:38 AM
code33 Offline
'96 & up are ODB-II (federal mandate). Plus, CA, which is more picky. You may be able to get Magnaflow 43000 series and pass SMOG. If you know of a SMOG tech, I'd check w/ him first.
ODB-II is PITA... That cat efficiency code will usually put a vehicle into limp mode (decreased performance).
Re: Where to get cats for '99 CA [Re: code33] #744988 08/19/06 08:47 AM
52degrees Offline
Just go to a muffler shop and tell them you need an OBDII catalyst. They'll do the rest, and usually cheaper than anywhere else you could go. Just be sure to shop around.
KG6VNX
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5940 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-07-17 02:14:47 UTC
