my hood is coming apart #744996 08/16/06 12:07 AM
P
poolville02 Offline OP
Not a real technical question but maybe someone has fixed this very annoying problem before. Basically, The glue stuff that holds the hood skin to the rib structure is no longer holding. Now the hood vibrates like a mofo. What should I use to glue it back together? Needs to be able to take the heat from the engine.
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
Re: my hood is coming apart [Re: poolville02] #744997 08/16/06 01:13 AM
trythis Offline
I vote for JB weld. Or maybe the alimunim duct tape, not duck tape.
You could rivet it with stainless pop rivets in a nice pattern.
Re: my hood is coming apart [Re: poolville02] #744998 08/16/06 02:34 AM
eightyeight Offline
spot weld it real careful-like? thats what id do. or yeah, jb weld would work.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: my hood is coming apart [Re: poolville02] #744999 08/16/06 03:05 AM
yodta Offline
this is common.
mine's been like this since I bought it 6 years ago.
been curious about this as well...
jb weld probably isn't the stuff to use though -- you'll notice that this stuff on the hood is kinda squishy & somewhat pliable.
I've been thinking about getting some of that underhood insulation from JC Whitney anway. could probably stuff some of that up between the hood skin and the support runners before putting the main insulation sheet up.
just my .02...
msg - '87 xtracab
Re: my hood is coming apart [Re: yodta] #745000 08/16/06 05:03 AM
OOP'S Offline
JB Weld will not work, it needs to stay somewhat pliable. Go to an auto paint supply place and see what they suggest. Mine has been like that for years, but it does not bother me, trail rig only.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: my hood is coming apart [Re: yodta] #745001 08/16/06 05:13 AM
RatLabGuy Offline
this is common.
jb weld probably isn't the stuff to use though -- you'll notice that this stuff is kinda squishy & somewhat pliable.
just my .02...
Not ideal solution - but if either of you can come up w a shipping method, I happen to have 2 extra hoods sitting in my garage...
otherwise, I 2nd JB weld, w/ real wled being more ideal but only if yer good and can avoid heat/distortion problems.
Question Reality.
Re: my hood is coming apart [Re: poolville02] #745002 08/16/06 05:37 AM
Kona Offline
I say if you can't weld it, JB weld it. I used some on my radiator 4 years ago with the intention of replacing the radiator when the JB failed. It's still holding after mutiple croos country trips and a 130 degree drive through Death Valley last summer. Worst case scenario, it fails and your out three and a half bucks.
Back in the West!
Re: my hood is coming apart [Re: OOP'S] #745003 08/16/06 06:30 AM
P
I think OPP's is right about it needing to be pliable. It also seems like there is supposed to be a small gap in between the skin and support....which prevents me from getting them flush to tack weld them together (or JB weld). The original glue stuff is almost like a rubber or silicon...guess I'll start looking for something similar.
Re: my hood is coming apart [Re: poolville02] #745004 08/16/06 07:27 AM
Snowtoy Offline
Liquid nails will woratleast it did on a truck I sold last year. Whatever epoxy you choose, you will want to let it set-up before driving.
You could also wedge a piece of wood or thick rubber behind it, using a set screw through the rib to hold it in place.
Re: my hood is coming apart [Re: Snowtoy] #745005 08/16/06 01:30 PM
trythis Offline
How about silicone. 100% only, not acrylic caulk. Silicone is $4.00 and can take some heat. Pretty sticky!
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6374 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-11-03 12:23:18 UTC
