puttin a cluth in a 94 toyota truck 22re #745092 08/16/06 03:38 AM
i need some info on how to replace a clutch cause its just startin to slip so i would really like some help with this. if i could get any links to where i can find this information and stuff that would be great
Re: puttin a cluth in a 94 toyota truck 22re #745093 08/16/06 04:59 AM
OOP'S Offline
There is a copy of the Factory Service Manual at the top of this BB. It is for a 93, but it is the same. Make sure to get your flywheel resurfaced.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: puttin a cluth in a 94 toyota truck 22re #745094 08/16/06 09:17 PM
9
92daily Offline
Get a transmission jack, makes life alot easier. If you dont have a body lift on your truck, you will want to unbolt the crossmember first, lower the transmission, then get the top bell housing bolt off FIRST!
As previously mentioned, see the FSM for the general step-by-step procedure. It's a pretty straight forward job.
I'm between toyotas right now... 3rd Gen 4-runner soon.
Re: puttin a cluth in a 94 toyota truck 22re #745095 08/16/06 09:28 PM
thanks for the info
Re: puttin a cluth in a 94 toyota truck 22re #745096 08/18/06 04:32 AM
babyhuey Offline
Trans jack and a buddy are mandatory.I used cheap floor jack adapter and ratchet straps.Bought trans jack after that.You will need a bushing kit for the shifter[yours is cracked by now,marlin crawler makes heavier duty pieces}.Advance has new flywheels cheaper than you can turn them.Next one I do I will use factory spec clutch,as my heavy duty LCE clucth chatters alittle bit[might go away after wear in.Make some long studs to guide trans up on bellhousing.Do not use bolts to pull trans in or mainshaft will push out your pilot bearing.Be safe,its an easy job.
Re: puttin a cluth in a 94 toyota truck 22re [Re: babyhuey] #745097 08/19/06 03:36 AM
I would do the rear main seal while its out. I think every toyota I've had has leaked oil there at one time or another. And look into the shim kit to go with it. I don't know alot about it but I was told about it AFTER I did my new seal and it all ready leaks less than 2,000 later.
Re: puttin a cluth in a 94 toyota truck 22re #745098 08/20/06 01:57 AM
MAC Offline
what is the 'shim kit' ? I'm putting a used 22re in soon and was thinking that the rear main may be something that maybe I should do...although it only has 45K or so on it.
Re: puttin a cluth in a 94 toyota truck 22re [Re: MAC] #745099 08/20/06 06:48 PM
V
vtown Offline
"shim kit" a.k.a "speedy sleeve".
It's a cap that goes on the end of the crank(front/rear). You use one if a groove has worn in the crank from the old seal rubbing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6163 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-05-29 22:18:32 UTC
