battle wagon pics
#745356
08/17/06 12:42 AM
haha my buddy called it that on a recent trip to the outer banks I think i'll keep it anyways here are some pics. got some herculiner on it. I think I will go higher with it though to keep it flowing along the sides. I did not due the front bumper as it will be coming off for tube. the rear bumper was built thanks to Matt at indy4x. it turned out great. hope the pics do it justice. Now all I have to do is solve the probelm of a slit sidewall on one of the tires and I will be ready for calalantee. Front bumper may not make it in time well see. let me know what you think. ![[Linked Image]](http://i11.photobucket.com/albums/a161/anubiscustoms/Picture206.jpg)
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: battle wagon pics
[Re: anubis]
#745357
08/17/06 12:52 AM
Looks good <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I like the rear bumper, Matt did a supurb job on it
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power '92 Rodeo...work in progress Hmmmm...DIRT!!!
[Re: anubis]
#745358
08/17/06 03:03 AM
I like the look...its a great looking rig so far. I would run the herculiner up to the style line on the side of the doors personally if it were me....just because the rear follows that line and then it stops and goes down lower on the doors. I dunno...I dont think it looks bad that way at all by no means....if you could p-chop it to see what it would look like that far up it might give you a better idea as well......great ride though....
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
[Re: icysyrup]
#745359
08/17/06 03:50 AM
yea once I pulled the tape off I was thinking the exact same thing. I will continue it around the back tailgate as well. That should finish it off.
[Re: anubis]
#745360
08/17/06 03:59 AM
I will continue it around the back tailgate as well. That should finish it off. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: icysyrup]
#745361
08/17/06 04:59 AM
the probelm of a slit sidewall on one of the tires I got a suggestion, I think with that much lift, the battle wagon needs 33s <img src="/forums/images/graemlins/evil.gif" alt="" /> See ya in Callalenitantee.
[Re: Rodeo Guy]
#745362
08/17/06 08:27 AM
You got some pipes under it? Looks good. Just be careful you don't get the tail pipe hung up on some big rocks.
CHRIS 98 Amigo, 92 Pup
[Re: CPOM]
#745363
08/17/06 01:05 PM
that tail piep should be fine. I almost ordered 33's on monday from matt. I was hopeing to make it till next year before throwing that cash out. I wanted to get the bumpers on and then hit up the tires. I might need to extend the rear control arms. I see that with 32's I have hit the rear door and bent some metal. That may be next option.
[Re: anubis]
#745364
08/17/06 04:06 PM
I have a stupid question.
From the picture, it appears you can't open the doors due to the rocker protection.
Can you open the doors all the way?
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
[Re: anubis]
#745365
08/17/06 04:32 PM
Yep, æBattle WagonÆ sounds about right <img src="/forums/images/graemlins/kewl.gif" alt="" /> that tail piep should be fine. Probably -- but if you decide to try the waterfall on Welder, that thing is toast <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
