odometer change
#745892
08/19/06 07:46 PM
I just purchased a speedo/tach instrument panel to replace the standard speedo only dash in my '88 pickup. I know I need to replace the oil pressure sender. I would like to roll back the miles about 30K to match the speedo I'm replacing. Is this hard to do? Anyone that can tell me how to do it please. TIA, Roy.
Hand me that crowbar.
Re: odometer change
[Re: krauthead]
#745893
08/21/06 10:39 PM
There are write ups on how to do it. Technically it's illegal to mess with them at all (in terms of roll back). It's not easy to roll them back and I don't recommend it.
The *easiest* thing to do is to take the odometer roll (the thing with all the numbers on it) and swap this between the speedometers. It's easiest to do this by disassembling the speedometer itself. Pay attention to the speedo's are assembled as you'll want to get the trip meter.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
Re: odometer change
[Re: dcg9381]
#745894
08/22/06 03:19 AM
i second that it is easier to move the onld to the new. They are built so that it is a pain in the rear to change. Swapping them can be a pain if the needles arent the same design, but it is doable.
Re: odometer change
[Re: trythis]
#745895
08/23/06 02:21 AM
Check this out. cluster swap It's what I used when I changed mine. I actually thought it was easier to roll it back, but that's just my 2cents worth.
Re: odometer change
[Re: yotaman7]
#745896
08/23/06 02:42 AM
I did it when I swapped in my sr5 cluster... was a pain but I did it.
-Scerb
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-05-29 15:19:29 UTCValid HTML 5 and Valid CSS
