fuel lines
#745996
08/20/06 03:47 PM
Recently finished reassembly of my 22-re(89 runner), after a good long test drive i noticed a strong gas smell. Upon further inspection i found the leak coming from the right frame rail under the passenger door. Thinking i've mixed up some lines to the charcoal canister as they are full of fuel, and the bottom hose disapears into the frame rail right where the leak is.TRying to figure out the location of these lines but my manual doesnt show any fuel line diagrams at all. Any help would be great.
82 4x4- tipped flipped & sunk. A "work in progress"
Re: fuel lines
[Re: Jake]
#745997
08/20/06 04:47 PM
Probably the cannister is full, not being flushed properly. 3 lines to it, the P line on top goes to the P port on the throttle body (P=Purge). The other line on top goes to the fuel tank vent and the bottom line is just run down to the frame rail to atmosphere: http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/19.htmlThe FSM has the testing an cleaning instructions.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5914 MB (Peak: 0.6395 MB) Data Comp: Off Server Time: 2026-05-29 22:16:04 UTCValid HTML 5 and Valid CSS
