Blinker woes #746067 08/21/06 12:18 AM
Yaker Offline OP
I just built a flat bed and a front bumper. There great but my new blinkers front and rear still blink to fast, like there is one bulb out. I have been told that I need a heavy dutie flasher, because of the extra juice going through it.
Just looking for some advice, Thanks.
Work smart not hard!
83 SR5 Pickup, 4" home brew lift, 36 inch TSLs ,locked front and rear, 4.7 t-case gears, 5.71 diff. gears, cross over high steer, 8k warn, custom bumper and flat bed, and huge plans.
Re: Blinker woes [Re: Yaker] #746068 08/21/06 02:35 AM
ron86toy Offline
need a resistor in-line both sides, ihave same problem running l.e.d.'s....they draw just about no voltage
86 4runner,sas,35's,all pro d60 hybrid locked,rear spooled
Re: Blinker woes [Re: ron86toy] #746069 08/21/06 03:23 AM
4Crawler Offline
Actually a resistor in parallel with the light is one option, helps to increase the *current* to make the factory flasher relay think the bulbs are OK. For the flatbed wiring, might need to add blocking diodes to make the lights compatible or modify the flasher to flash slower:
http://www.pirate4x4.com/forum/showthread.php?t=463125&highlight=fast+blinker
Re: Blinker woes [Re: Yaker] #746070 08/21/06 07:04 AM
Snowtoy Offline
A buddy of mine had the same problem, so he added a second small turn signals(about 1,5" diameter) mounted just inside the wheel well on the bumper. The extra power it consumed returned the blinker flash to normal, and the 2nd blinker alerts drivers along side him.
Re: Blinker woes [Re: Snowtoy] #746071 08/21/06 09:46 PM
Yaker Offline OP
Thanks for the help. I love both Ideas. This is always the place to find easy fixes. You guys ROCK.
Re: Blinker woes [Re: Yaker] #746072 08/27/06 04:28 AM
Yaker Offline OP
That works out great! Cheep and free, what else could you ask for. Thanks for the info.
Re: Blinker woes [Re: Yaker] #746073 08/28/06 04:10 PM
dcg9381 Offline
You can also snip a resistor on the relay that powers the TS for a constant rate blink.. you won't know when one fails however.
22REturbo.net
1988 4Runner
Re: Blinker woes [Re: dcg9381] #746074 08/28/06 04:41 PM
Jason22RET Offline
Fast easy cheap, go to your parts place and get the square heavy duty truck (18 wheeler) realy. You may have to make a pair of leads to connect it up. Pop off the cover and you will find a pot (adjustable Resistor) in there that allows you to dial in the speed you want. Big rigs need these because of the endless variations of turnsignal lamps and bulbs they may use. I use them in my cars just so I can set the speed I like. I use a speed just slower than normal cause I think it gives my car a cool subduded look that just gets your attention as a bit different. May sound funny but think of how a fast blinker makes you look nurotic and spazey <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Blinker woes [Re: Jason22RET] #746075 08/28/06 06:39 PM
Yaker Offline OP
I agree that slow blinkers are cool, but nothing is cheeper than free. Thats why I decided to use the resister trick.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6284 MB (Peak: 0.7309 MB) Data Comp: Off Server Time: 2026-05-29 16:41:37 UTC
