This should be interesting, squeak coming from 1989 trooper in drive (4cyl) #746099 08/21/06 03:50 AM
thepcguy Offline OP
Hey everybody, I've got a small issue that I've been trying to diagnose. My trooper (4cyl, automatic) will make a slight squeak as soon as you start moving in Drive (now that I think of it, haven't tried reverse) and then for every gear thereafter. It's a short squeak and only happens when shifting. I haven't ruled out the possibility that it's simply the body creaking on the mounts. This doesn't seem to be speed related. I can gently press the gas pedal and I can stomp on it and it'll make the same noise. I haven't had any luck having people on the ground listening to it as I drive yet. I did just get under the truck and grease up the driveshaft (thought it might be a u-joint or something). Basically, I know the truck is old, but I just want to make sure it's not coming from the transmission or transfer case. Well thanks in advance smile. Also, thanks to whichever mod moved my seafoam post. I didn't realize that I was in tech, whoops smile.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: This should be interesting, squeak coming from 1989 trooper in drive (4cyl) [Re: thepcguy] #746100 08/21/06 03:59 AM
lttlbddy Offline
If it is a high pitched metal on metal type sounds it could be a lot of things. I found cracks in my rear spring hangers - the shackle to frame mount.
Maybe metal/weld fatigue as opposed to worn bushings or u-joints.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5886 MB (Peak: 0.6376 MB) Data Comp: Off Server Time: 2026-05-29 22:43:39 UTC
