Page 1 of 3 1 2 3
VOTE: why not the original oem dealer muffler? #746134 08/21/06 05:37 AM
trooperbc Offline OP
is it cost?
they seem to last a good long time; so like many other isuzu replacement parts, why don't i hear anything about sticking with stock oem (dealer) for this too?
what's your opinion about sticking with oem dealer muffler?
please vote, but also please give me some written reasons/feedback, too.
thanks
bc
muffler: oem dealer or aftermarket?
single choice
Votes accepted starting: 08/20/06 05:00 AM
You must vote before you can view the results of this poll.
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: vote: why not the original oem dealer muffler? [Re: trooperbc] #746135 08/21/06 05:48 AM
lttlbddy Offline
OEM is expensive and very large!!
Re: vote: why not the original oem dealer muffler? [Re: lttlbddy] #746136 08/21/06 06:11 AM
CPOM Offline
I would be scared to ask a dealer for a price quote on a muffler including St Charles Isuzu. Second reason is why not upgrade any time you get a chance? Third is the OEM style mufflers are designed for amazing sound reduction but not necessarily with performance in mind.
CHRIS
98 Amigo, 92 Pup
Re: vote: why not the original oem dealer muffler? [Re: CPOM] #746137 08/21/06 02:46 PM
BigSwede Offline
Yeah IIRC the OEM muffler is at least $200...nothing wrong with it, probably a little more restrictive than a Dynomax Super Turbo or the like, but you can get a very nice lifetime warranty high performance muffler for under $100.
Serenity now!
Re: vote: why not the original oem dealer muffler? [Re: BigSwede] #746138 08/21/06 03:35 PM
Smiley Offline
Price is a factor, to be sure û but like noted above, the physical SIZE of the OEM muffler might be a consideration as wellà
The OEM does a mighty good impression of an oil drum - and because of this, off-road, they are all-the-more-likely to make contact with rocks (as literally dozens of scrapes and dings on mine provide ample evidence <img src="/forums/images/graemlins/shiner.gif" alt="" /> )
An aftermarket muffler, with its shallower vertical profile, can be mounted a little bit farther up out of harmÆs way û and every fraction of an inch helps.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: vote: why not the original oem dealer muffler? [Re: trooperbc] #746139 08/21/06 06:39 PM
Gizzy42 Offline
For me its about sound more then anything. Stock muffler would be fine with me if it wasnt so quiet. Ok price has some to do with it too. I looked up the cost from slhonda.com, their price for a stock muffler is $186. They want $109 just for the tail pipe <img src="/forums/images/graemlins/zombie.gif" alt="" />
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: vote: why not the original oem dealer muffler? [Re: Gizzy42] #746140 08/21/06 07:21 PM
lttlbddy Offline
Another reason the size does matter (honest smaller is better!):
On the 1st gen Amigos, when we need a new exhaust system, we try to run it straight down one side of the floor pan. The original exhaust has the muffler on one side, the cat on the other and crosses over twice.
The shorter aftermarket muffler and cat, make this work, where as with either stock component, there just isn't room to make the fix.
That said, re-routing the exhaust probably isn't legal in [edit]many[edit/] states.
Re: vote: why not the original oem dealer muffler? [Re: lttlbddy] #746141 08/21/06 07:33 PM
BigSwede Offline
But California isn't like "most states"...even here in Minnesota, which by Midwestern standards is a pro-regulation state, there is no prohibition on rerouting exhaust, and no inspection program in any case.
Which is nice because I just had part of my exhaust re-routed to cross over behind the t-case instead of under the tranny. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm still EPA legal though, cat and all.
Serenity now!
Re: vote: why not the original oem dealer muffler? [Re: BigSwede] #746142 08/21/06 10:16 PM
lttlbddy Offline
Fortunately, that is an area that the smog nazis don't pay much attention to even in CA. As long as it has all the parts in the correct order, they are happy.
That was meant only as a disclaimer.
Re: vote: why not the original oem dealer muffler? [Re: trooperbc] #746143 08/21/06 10:28 PM
sneekyeye Offline
I say aftermarket because you get more bang for the buck, and can have it done how you want it. You can replace it with something smaller and have it do a good job too.
90 amigo 2.6 4wd calmini cam and header
Junkyard Rancho 5000's.... Lifetime warranty right?
Amigos don't run on gasoline,
They run on Love... <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 19 (0.007s) Memory: 0.6539 MB (Peak: 0.8252 MB) Data Comp: Off Server Time: 2026-06-17 03:24:59 UTC
