Re: Electrical Issue [Re: 4Crawler] #746291 11/19/06 08:06 PM
ad54runner Offline OP
I have good metal to metal contact and there is no change. The turn signal still cuts off the gauges.
Chris
1985 Toyota 4Runner - Longfields, 5.29's, EZ Locker F/R, Marlin X-Over, Rancho 99012's, 35" BFG AT KO, 414K miles.
1996 FZJ80 stock with 191K miles.
1980 FJ40 stock with 85K original miles.
Re: Electrical Issue [Re: ad54runner] #746292 11/19/06 10:26 PM
Z
zachtheterrible Offline
Try twisting your dimmer switch around and seeing what happens, since that should be in series with all the instruments you mentioned.
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Electrical Issue [Re: zachtheterrible] #746293 11/30/06 03:32 PM
I fiddled with the dimmer switch and it works normally. The lights get dimmer and brighter. There isn't a problem with the dash lights, just the gauges.
I don't understand how pulling a fuse and putting in the same fuse can reset something. Is there a breaker somewhere in that circuit? Like I said I suck at this electrical stuff.
Chris Sutton
Golden, Colorado
Re: Electrical Issue [Re: ad54runner] #746294 11/30/06 04:26 PM
4Crawler Offline
I once had a situation like that in my '85. Had been in a shop for a week or so and when I started off driving, after an hour or so everything just died on the dash. I pulled off the road, shut off the engine and pulled/inspected every fuse. Nothing was out of the ordinary, so after sticking all the fuses back in, turned the key and all was normal. That was 8 years ago and it has never repeated. I assume it was a fuse or holder that had oxidized contacts and with it sitting a while without running, that may have been enough to trigger the problem. The act of pulling and re-inserting the fuse scraped the oxidation off the contacts and thus "fixed" the problem.
Re: Electrical Issue [Re: ad54runner] #746295 01/29/07 02:41 PM
Ok, so I have been messing with this thing for a while. The weather has prevented me from spending a whole day just getting this fixed. At this point I have replaced all of the standard fuses in the truck, new alternator and new battery. I charged the battery myself, so I know it is fully charged. It starts now without being jumped and the gauges all work. The last problem is that I am still getting a charge light. With everything I have replaced does this sound like the 80 amp alternator fuse? It doesn't look like it has blown, but I bought one anyway.
Man I hate this electrical stuff. Give me a broken spring any day.
Chris Sutton
Golden, Colorado
Re: Electrical Issue [Re: ad54runner] #746296 01/29/07 09:43 PM
toowacky Offline
I hear ya, electrical issues are the worst for me. Not sure if this applies, but when I had my '84 p/u, I was diagnosing a charging issue. On my truck, with the external voltage regulator, there was also the 'charge lamp relay' which IIRC was on the driver's side, kick panel area. I believe it was last in trouble-shooting the 'charge' lamp staying on, but you may want to check to see if you have one. I had no idea there was a relay under there. Good luck. Tom
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: Electrical Issue [Re: ad54runner] #746297 01/30/07 01:10 AM
Stevie Offline
Is the light bright, or dim with RPM?
'80 4X4 Longbed
Re: Electrical Issue [Re: toowacky] #746298 01/30/07 07:46 PM
I will look at that if changing the alternator fuse doesn't fix the problem.
Re: Electrical Issue [Re: Stevie] #746299 01/30/07 07:48 PM
The charge light is pretty bright. I didn't rev it as I was just happy it started without a jump. I don't think it will hurt anything to change the alternator fuse, so we will see if that helps.
Re: Electrical Issue [Re: ad54runner] #746300 02/05/07 02:46 PM
Well the new alternator fuse is in and everything is working normally. I drove it to work today. I am not sure that I really did anything to fix my original problem. It must have been a combination of corroded fuses and messing with them without disconnecting the battery caused me to blow the alternator fuse. Thank you for everyone's suggestions, although I don't know if searching this thread will help anyone else.
Chris Sutton
Golden, Colorado
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.015s) Memory: 0.6408 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-11-04 13:37:01 UTC
