how do you torque a crank pulley bolt? #746373 08/22/06 01:52 AM
StockRaider Offline OP
I just got around to change my crank bolt and I can't get it torqued to 112pounds like the book says. I tried stopping the steering pump pulley with a wrench but the belt slides around it when I start torqing it. I was going to pull the starter and stick a breaker bar against the flexplate but I am afraid of cracking it. Any ideas?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: how do you torque a crank pulley bolt? [Re: StockRaider] #746374 08/22/06 02:31 AM
FrankR Offline
A 3.0L crankshaft pulley should be torqued to 134 lb-ft, +/- 3 lb-ft. I'll let others describe various methods for holding the pulley stationary.
Frank
Re: how do you torque a crank pulley bolt? [Re: StockRaider] #746375 08/22/06 02:34 AM
Tag Offline
How did you hold it still to get it out? Cant you reverse that? Heck I purchased my bolt and was never able to get the old one out. So I just keep checking it to make sure it is tight and will change it when timing belt time comes along in apx 20000 more miles.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: how do you torque a crank pulley bolt? [Re: Tag] #746376 08/22/06 02:38 AM
mine came out by jerking it with a breaker bar and it came right off.
Richard E
1983 Honda XL600R
Re: how do you torque a crank pulley bolt? [Re: StockRaider] #746377 08/22/06 02:47 AM
Mad_Scientist Offline
Doesn't the 3.0L engine have the two holes on the crank pulley like the 3.5L? I made a tool that inserted in those holes to hold the pulley still. May be I'm just showing my lack of knowledge about the 3.0L here... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: how do you torque a crank pulley bolt? [Re: Mad_Scientist] #746378 08/22/06 02:53 AM
Tag Offline
Yes they are supposed to. Matter of fact I got one of the tools on loan from DougB to hold mine still. But my pulley was slightly different then most people on this forum have so it did not work.
Re: how do you torque a crank pulley bolt? [Re: Tag] #746379 08/22/06 02:55 AM
Tag Offline
Wait a minute I just thought of something. Maybe my pulley looks more like yours. Do you have any pics? Maybe mine has been switched out with a newer one by the previous owner.
Re: how do you torque a crank pulley bolt? [Re: Tag] #746380 08/22/06 03:16 AM
Raider_X Offline
i used a belt wrench thingy before.
RIP raider
Re: how do you torque a crank pulley bolt? [Re: Raider_X] #746381 08/22/06 03:22 AM
LandRaider Offline
Wrap the belt up on it, and put the belt over another one of the pullys. Ought to tighten up on it good enough to get your appropriate torque. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: how do you torque a crank pulley bolt? [Re: LandRaider] #746382 08/22/06 03:31 AM
sparkem Offline
I use an old serp. belt wrapped around it and wrap the other end to something stationary, just like Landraider said. Works every time.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6483 MB (Peak: 0.7673 MB) Data Comp: Off Server Time: 2026-11-17 11:29:21 UTC
