3.0 not quite there after top end rebuild #746540 08/22/06 05:19 PM
P
Paul_H Offline OP
So I finally got my 3.0 back together with e/b built o/s valve heads, modded the crossover per my previous post, and got all the hoses back in the right spot and dialed in the ignition, and walla it runs. The first test drive or too it felt fine other than an exhaust leak where my crossover eliminator ties into the downpipe, too be fixed.
Trouble is, I drove to work yesterday ~15 mile 1/2 hour commute, first time the engine really warmed up since the rebuild. Now I notice at idle it misses a bit and kinda stutters until it gets a bit of gas. I'm befuddled as to what is causing this.
I did have an engine light that would intermittently come on, and after checking the two 02 sensors, the rear one was out of range and replaced, and now no check engine light.
Any suggestions greatly appeciated. I did replace the rotor and cap before the rebuild, and put in new plugs. The oil and coolant looks fine.
'94 extra-cab 3.0 extra slo (auto tranny) original owner. E/B o/s valve heads and no more crossover. More mods to come.
Re: 3.0 not quite there after top end rebuild [Re: Paul_H] #746541 08/22/06 11:02 PM
L
lostone Offline
Re- check your vacume hoses, you may have a small leak somewhere. Another thing is it might be yor TPS. The one on my 4runner went bad after a rebuild. I also had a bad one on my chevy and it would cause the idle to surge.
Re: 3.0 not quite there after top end rebuild [Re: lostone] #746542 08/22/06 11:43 PM
Ganoid Offline
I had to disconnect the EGR to get the stutter out of mine. I just haven't managed to get around to reducing the EGR inlet pipe and hooking it back up. You may want to try pulling the hoses off the EGR and plugging them to see if that's the direction you need to go.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: 3.0 not quite there after top end rebuild [Re: Ganoid] #746543 08/23/06 01:50 AM
P
Paul_H Offline OP
Thanks for the tips. I didn't even take the throttle body off of the intake manifold, so am hoping the TPS is still good. The rpm doesn't surge at all. It's just I get some missing and hesitation at idle and the throttle barely cracked. Once the rpm come up a bit, or I give it more gas, it seems fine.
I need to get it smogged, so don't want to defeat anything that may prevent that. #1 one thing is to find the leak(s) in the exhaust and weld it up.
Re: 3.0 not quite there after top end rebuild [Re: Paul_H] #746544 08/23/06 02:46 PM
half_fast Offline
sounds like an air leak on the intake side. Remove the plastic between the TPS and the MAS and Ill bet you find a crack, just like I found one on mine. But those pieces arent cheap... $95 to replace but I found no way to reliably fix.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-05-29 16:21:03 UTC
