I've got two plugs grounding out #746931 08/24/06 05:15 AM
L
lostone Offline OP
I went outside tonight and started up my truck beacuse I had a suspicion that one of my wires was grounding out beacuse the engine would idle rough and lack power at low speeds and miss. Sure enough I have a little light show coming from cylinders 1 and 6. The engine was rebuilt about 400 miles ago and the wires are brand new. I have spark plug heat sheild sleeves around all the spark plug boots beacuse I have downey headders. Would this cause the wires to ground out?
Re: I've got two plugs grounding out [Re: lostone] #746932 08/24/06 02:21 PM
ZUK Offline
I bet those new wires came from Checkers or AutoBone.....you can get wholesale pricing on Genuine Toyota quality from here..... http://firsttoyotaparts.com
Are those heat shield sleeves of a metallic nature?....or are they of the white woven silk sock variety?
mostly stock
Re: I've got two plugs grounding out [Re: ZUK] #746933 08/24/06 05:16 PM
L
lostone Offline OP
no way, I stay away from cheap stuff on my trucks. I got mine from napa, they were the premimum wires and cost over 40 bucks which is why I'm P.O.'d I hate wasting money.
Theses are the heat sheilds I have>
http://store.summitracing.com/partd...mp;N=700+310833+115&autoview=sku
Re: I've got two plugs grounding out [Re: ZUK] #746934 08/24/06 05:42 PM
ZUK Offline
Where is the arcing at? real close to the boot?
mostly stock
Re: I've got two plugs grounding out [Re: ZUK] #746935 08/24/06 05:45 PM
L
lostone Offline OP
as far as I can tell it is at the end of the boot.
Re: I've got two plugs grounding out [Re: lostone] #746936 08/24/06 05:48 PM
BrokeAsAJoke Offline
I have to replace those "lifetime" wires every year. The expensive, top of the line Bosch seem to be the worst that I ever used. Someday I'll wise up and buy OEM. Believe what they say here: These trucks don't like aftermarket wires.
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
Re: I've got two plugs grounding out [Re: lostone] #746937 08/24/06 05:50 PM
4Crawler Offline
You might want to pull those plugs and look for carbon tracks on either the plug insulator or on the boots. Try cleaning both really well and see if that helps. Maybe there was some grease or other contaminant on either that led to the arcing.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6176 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-06-17 13:40:42 UTC
