1991 trooper tire sizes #747101 08/25/06 12:35 AM
P
PurplePeopleEatenTrooper Offline OP
I just recently got a 91 izusu trooper 4 doar with a 2.6 4cyl now i cant afford to put and lift on it and tires rightn ow so im just gunna get some tires...now i was wondering what the biggest tires i can fit on there with out rubbing or causenig any tranny problems if i had to guess i think i can get 31-10/5s on there but my step dad who thinks he is almighty machanic says no way and if i could then the trannys gunna blow...( just for the record he palys music fora liveing) thanks for your tiem and puting up with my horibal spelling <img src="/forums/images/graemlins/cheers.gif" alt="" /> [color:"purple"] [/color]
Re: 1991 trooper tire sizes [Re: PurplePeopleEatenTrooper] #747102 08/25/06 01:05 AM
88SuperTrooper Offline
31x10.50x15's are the biggest I would go with out a lift and they wont rub. with a 3 inch lift you can runa 33", AND no your Tranny IS NOT GOING TO BLOW!!! I have an Auto and a Standard, never had a Problem them at all. Are you running the stock steel wheels or the "SnowFlake" OEM Aluminums?? With my Experiance with the stock wheels, Running a 31" tall tire its no good for the wear and it feels like the handeling off and on road is "tipsey", not saying It will roll over, but thats the feeling I get. I just Bought some after market 15x8 Eagle 058's that will help with the feeling I get Offroad plus make the tires wear better. AND of course Make it Look better.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: 1991 trooper tire sizes [Re: 88SuperTrooper] #747103 08/25/06 01:14 AM
P
ya unfortinutly i have the stock wheels... i have a low amount of money due to being 17 and working at mc.donalds and haveing my own apt.....so i was gunna try to find some used wheels around where i live... now by 3 " lift did u mean sup or bl or dose it evan matter as long as it equals at least 3"
Re: 1991 trooper tire sizes [Re: PurplePeopleEatenTrooper] #747104 08/25/06 01:25 AM
I meant 3" suspension Lift, With that YOU CAN run a 33" other than that a 31 will fit and you can get them for about 80 to 125 $$ and they go up from there.
31" Big O X/T's
15x8 Eagle 058's
Re: 1991 trooper tire sizes [Re: 88SuperTrooper] #747105 08/25/06 01:43 AM
maxwell417 Offline
33x10.5r-15s fit with no lift. I have had the tires mounted on 3 diffent sets of rims:
1. Stock alloy 15x6 rims looked a little narrow, minor rubbing of the inner fender at full lock.
2. Steel 15x8 fit great no complaints. Pictured below.
3. Alloy 15x7 About the same as the 8"s, but lighter weight helps somewhat in gitty up performance department.
I did crank the torsion bars a little and weld up some shackles. But the lift is not relevant, bumps stops are stock.
On the other hand 195/50r-15s fit with a 3" BL and 3" suspension lift.
Only minor rubbing / dragging in my driveway <img src="/forums/images/graemlins/lol.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 1991 trooper tire sizes [Re: maxwell417] #747106 08/25/06 03:04 AM
9
94redrodeo Offline
I run 35" s with the stock tranny and some troopers came stock with 31's all you "have" to do to lift is buy longer shackles which you csn get cheap ones for $20 and crank the torsion bars that will give you 2" lift
maxwell I am Rotflmao <img src="/forums/images/graemlins/lol.gif" alt="" />
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: 1991 trooper tire sizes [Re: 94redrodeo] #747107 08/25/06 03:33 AM
thepcguy Offline
I think I just threw up in my mouth a little. Itty bitty tires.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: 1991 trooper tire sizes [Re: PurplePeopleEatenTrooper] #747108 08/25/06 03:49 AM
litnin Offline
The Troopers came stock with 31-10.50/15's if you had
the big tire and wheel package.
They also had 4.77 gears instead of the 4.56's that come
with the smaller tire package. There was no difference
in the transmissions between the big tire and wheel package trucks and the ones without the package.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: 1991 trooper tire sizes [Re: maxwell417] #747109 08/25/06 04:37 AM
OMG, You fit them with no lift other than your torsions...... WTH I tried them on 15x8's that I had, they rubbed BADDD with torsions CRANKED, WOW. wonder what difference was??? oh well. Luckly I was able to get that Tire Package on mine and got the lower gearing. BTW, HAHAHA nice pics man, HAHAHA low rider. HAHAHA still giggling.
31" Big O X/T's
15x8 Eagle 058's
Re: 1991 trooper tire sizes [Re: maxwell417] #747110 08/26/06 01:25 AM
maxwell417 Offline
The key thing is 33x10.5r-15 Narrow fits easy
I also did put my 33x12.5r-15s on the RS for a couple weeks. Because it was hot 100* and I didn't feel like using my HF manual tire changer right then. I did have some minor rubbing at full lock and they might have rubbed if flexed, didn't try it, I was too busy with work and getting ready for CoZu.
The extra weight difference between 10.5" tires on alloy wheels and 12.5" tires on steel is something to consider. Heavy will make you want better shocks and more power. I don't really notice the heavier 12.5" rubber on steel wheels in my 3.4v6 Trooper. But I really noticed the difference on the 2.6 4 cyl RS Trooper
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6404 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-11-01 17:14:40 UTC
