More progress on my Diesel Trooper #747608 08/27/06 04:12 AM
Re: More progress on my Diesel Trooper #747609 08/27/06 05:23 AM
A
acy76 Offline
Looking good. What did you end up doing for motor mounts?
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: More progress on my Diesel Trooper [Re: acy76] #747610 08/27/06 06:56 AM
TxMiniTruck Offline
Wow Solomon your making alot of progress. Looks like the water neck will be one of your hardest task to overcome. By what I see from the photo of the firewall there must not be much room. Are you going to have problems with what I think is the heater core lines coming out of the firewall? Keep us updated.
Damon from Texas
Damon
N.E. Texas
Re: More progress on my Diesel Trooper #747611 08/27/06 12:30 PM
crossbones Offline
Hello Solomon. Your conversion looks great......good work.........
Did you have any oil pan or clutch issues to address?
crossbones
1982 Luv Diesel 4X2
1982 Luv Diesel 4X4
1981 Luv diesel 4X2
1983 Isuzu Diesel 4X4
1986 Trooper TD
Re: More progress on my Diesel Trooper [Re: crossbones] #747612 08/27/06 04:45 PM
So far I have not worked out the motor mounts, that is next. The engine is setting in there so I can get a feel for where the mounts will go.
The clutch is not an issue, it is the facotry Trooper clutch on the original trans. I am also using the factory Trooper flywheel. Fits just like the factory intended.
The water neck is a bigger issue. I am going to have to make a t-stat housing that moves the t-stat up and out a little.
The vacuum pump is another issue. It was down on the drivers side at the bottom, it will be relocated to the top of the drivers side.
While it is a tight fit and there are some issues, this has been by far easier than I expected. There are more things that just fit than I thought would. It helps going from one GM engine to another.
Its too bad there are not a lot more 4.3L diesels out there to be had, I could create a kit for doing the swap.
I am looking forward to getting this thing done and driving it.
Re: More progress on my Diesel Trooper [Re: crossbones] #747613 08/27/06 04:47 PM
I forgot, the oil pan was an issue also. I removed it, made some cuts and reshaped it. I will be adding metal back to close up the hole, but right now it still needs to be rewelded. I needed to put the engine in the hole to make sure the mods I made were right. So far it looks good.
Re: More progress on my Diesel Trooper #747614 10/20/06 01:55 AM
TxMiniTruck Offline
Anymore progress? Cant wait to see the end result and hear the seat of pants report.
Damon
N.E. Texas
Re: More progress on my Diesel Trooper [Re: TxMiniTruck] #747615 11/15/06 08:40 PM
A
acy76 Offline
Looks like it's up for sale...
Re: More progress on my Diesel Trooper [Re: acy76] #747616 11/16/06 04:31 PM
OutfitBoss Offline
Up for sale? What makes you say this?
Brian Rodgers
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: More progress on my Diesel Trooper [Re: OutfitBoss] #747617 11/16/06 06:06 PM
A
acy76 Offline
Check the classifieds on this site.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6322 MB (Peak: 0.7346 MB) Data Comp: Off Server Time: 2026-07-15 02:24:42 UTC
