Running lights out
#748235
08/29/06 07:48 AM
I have a small problem with my running lights on my 97 T-100. Both the front left and rear right running lights won't work. I've checked the bulbs and fuzes and that's not the issue. I have the Toyota tow package, could the transistor they installed be the problem?
Thanks,
Vern
Re: Running lights out
[Re: vernallis]
#748236
08/30/06 12:24 AM
I ran into some problems a few years ago with my truck. The taillights went out and when I pulled the connectors apart the terminals were all corroded and broken. I would suggest checking the conenctors near each light and make sure they are intact.
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
[Re: vernallis]
#748237
12/01/06 05:15 PM
Did you ever find the fix for this? I am having the same problem on my 96 T100 . Did this start after you had the steering recall done? I have a small problem with my running lights on my 97 T-100. Both the front left and rear right running lights won't work. I've checked the bulbs and fuzes and that's not the issue. I have the Toyota tow package, could the transistor they installed be the problem?
Thanks,
Vern
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5915 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-10-22 02:13:11 UTCValid HTML 5 and Valid CSS
