Lo-Med-Hi Blower Switch
#748543
08/30/06 01:39 AM
Any of you guys seen this?: Blower no workie on Lo and Medium, but great on Hi. Easy fix right? Replaced the resistor with a known good one, and CRAP: Still no Lo & Medium. Maybe it's the relay. Replaced with a known good one. Still no work. Alright..measured voltage at the blower motor connector: On my working '80 truck, it's 12 volts at all Lo-Med-Hi positions, so it's just the current that obviously changes, thanks to a good resistor. But on the project '80, it's around 5 volts on Lo & Medium. Switch to Hi and the volts go to 12, and works great. So, it's gotta be the Lo-Med-Hi switch, right? Anyone else seen this? If you have, and have the part number handy, I would love to hear from ya! <img src="/forums/images/graemlins/shiner.gif" alt="" />
'80 4X4 Longbed
Re: Lo-Med-Hi Blower Switch
[Re: Stevie]
#748544
08/30/06 02:23 AM
Most likely LMH switch ; remove and test before buying a new one.
85' 4x4 e-cab flatbed 22r carb ((SOLD)) 86' 4runner, 22re , "60 buck truck" 95' 4runner, 22re,5sd, last of the good ones 02' Tacoma prerunner, 2.7L, 5spd., 4x4
[Re: Cholltero]
#748545
08/30/06 03:46 AM
Those switches are known for going bad. Mine got so hot it melted the switch itself and stuck on hi. I had to unplug the switch from the fan so that it would shut off. When I showed it to the techs at the dealership, one guy said he had one on his desk. They said they replace them all the time, but mine was the worst he'd ever seen.
About $50 from the dealer part # 84732-35030 for a 90 pickup.
Good luck, Matt
'90 Pickup 22RE 4.30's, 31 STT's, MossyRock Sliders '90 2wd xtraCab, getting a heart transplant '88 4Runner with a thrown rod, waiting in the wings
[Re: tucker80]
#748546
08/30/06 03:58 AM
Thanks Matt. Appreciate it! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'80 4X4 Longbed
[Re: Stevie]
#748547
08/30/06 04:03 AM
No problem, I just hope it takes care of the problem.
[Re: Stevie]
#748548
08/30/06 04:20 AM
Steve I can check to see if I have one laying around. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Stevie]
#748549
09/05/06 05:50 PM
It ain't the switch! Swapped the blower switch from my driver to the project 4X4. Same result...only Hi works. Soooo....gonna buy the resistor, the proper one (non-air conditioned), as there's nothing left in the circuit. Anyone wanna bet this $22 part fixes it? <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> P.S.: Took the project's switch apart, cleaned the contacts (weren't too dirty or worn), and it ohm'ed out the same as before.
'80 4X4 Longbed
[Re: Stevie]
#748550
09/06/06 12:00 AM
Yes it's the blower resistor. My lowest speed didn't work so I ordered one from Autozone. Super easy to replace and a nice cheap fix.
'86 4Runner 5" SAS '97 4Runner '05 Corolla '00 F250 PowerStroke
[Re: Stevie]
#748551
09/06/06 01:25 AM
Blower resistor going out is pretty common. However, I've also had to resolder the fan switch in a couple rigs before.
[Re: kewlynx]
#748552
09/06/06 10:08 PM
Dammit! Went to RadioShack, bought a 1.2 and 2.7 ohm wirewound resistors, soldered them to their proper place in the resistor, mounted it and...still only works on HI! Those Toyota resistors can't be returned once bought. I'm looking at the blower motor now, Sheeeeeezz <img src="/forums/images/graemlins/scared.gif" alt="" />
'80 4X4 Longbed
