Lo-Med-Hi Blower Switch #748543 08/30/06 01:39 AM
Stevie Offline OP
Any of you guys seen this?:
Blower no workie on Lo and Medium, but great on Hi. Easy fix right? Replaced the resistor with a known good one, and CRAP: Still no Lo & Medium. Maybe it's the relay. Replaced with a known good one. Still no work.
Alright..measured voltage at the blower motor connector: On my working '80 truck, it's 12 volts at all Lo-Med-Hi positions, so it's just the current that obviously changes, thanks to a good resistor. But on the project '80, it's around 5 volts on Lo & Medium. Switch to Hi and the volts go to 12, and works great.
So, it's gotta be the Lo-Med-Hi switch, right? Anyone else seen this? If you have, and have the part number handy, I would love to hear from ya! <img src="/forums/images/graemlins/shiner.gif" alt="" />
'80 4X4 Longbed
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748544 08/30/06 02:23 AM
Cholltero Offline
Most likely LMH switch ; remove and test before buying a new one.
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Lo-Med-Hi Blower Switch [Re: Cholltero] #748545 08/30/06 03:46 AM
tucker80 Offline
Those switches are known for going bad. Mine got so hot it melted the switch itself and stuck on hi. I had to unplug the switch from the fan so that it would shut off. When I showed it to the techs at the dealership, one guy said he had one on his desk. They said they replace them all the time, but mine was the worst he'd ever seen.
About $50 from the dealer part # 84732-35030 for a 90 pickup.
Good luck,
Matt
'90 Pickup 22RE 4.30's, 31 STT's, MossyRock Sliders
'90 2wd xtraCab, getting a heart transplant
'88 4Runner with a thrown rod, waiting in the wings
Re: Lo-Med-Hi Blower Switch [Re: tucker80] #748546 08/30/06 03:58 AM
Stevie Offline OP
Thanks Matt. Appreciate it! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'80 4X4 Longbed
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748547 08/30/06 04:03 AM
tucker80 Offline
No problem, I just hope it takes care of the problem.
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748548 08/30/06 04:20 AM
Jeffstoyo Offline
Steve I can check to see if I have one laying around.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748549 09/05/06 05:50 PM
Stevie Offline OP
It ain't the switch!
Swapped the blower switch from my driver to the project 4X4. Same result...only Hi works. Soooo....gonna buy the resistor, the proper one (non-air conditioned), as there's nothing left in the circuit. Anyone wanna bet this $22 part fixes it? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
P.S.: Took the project's switch apart, cleaned the contacts (weren't too dirty or worn), and it ohm'ed out the same as before.
'80 4X4 Longbed
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748550 09/06/06 12:00 AM
4xJedi Offline
Yes it's the blower resistor. My lowest speed didn't work so I ordered one from Autozone. Super easy to replace and a nice cheap fix.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748551 09/06/06 01:25 AM
kewlynx Offline
Blower resistor going out is pretty common. However, I've also had to resolder the fan switch in a couple rigs before.
**ubi apis- ibi salus**
Re: Lo-Med-Hi Blower Switch [Re: kewlynx] #748552 09/06/06 10:08 PM
Stevie Offline OP
Dammit! Went to RadioShack, bought a 1.2 and 2.7 ohm wirewound resistors, soldered them to their proper place in the resistor, mounted it and...still only works on HI!
Those Toyota resistors can't be returned once bought. I'm looking at the blower motor now, Sheeeeeezz <img src="/forums/images/graemlins/scared.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6363 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-10-24 19:58:47 UTC
