360 swap
#748765
08/30/06 09:14 PM
So I have looked into it and it sounds like a AMC 360 will drop right into my CJ5 with no problem, new motor mounts, cross member and I am good right...now a few questions I have is will the exisiting power steering pump mount to the 360 or do I need to find one off a donor rig?? Will the clutch match up to the 360 flywheel or do I need a new clutch I know I have to use a 360 flywheel. And what carb is best to use with a 360 in a Jeep, I have a 390 Holley but not sure if that is going to be enough should I go with a 600 cfm or something along those lines?? <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 4.116s Queries: 14 (0.009s) Memory: 0.5816 MB (Peak: 0.6215 MB) Data Comp: Off Server Time: 2026-10-24 04:19:29 UTCValid HTML 5 and Valid CSS
