flex fan or stock clutch fan? #749077 09/01/06 05:07 AM
Bigbadtoy Offline OP
i was looking into getting a flex a lite flex fan but i dont know what size to go with i was wondering if any of u guys r running one what size works the best. Or if you guys think the factory clutch fan is better well let me know
i love playing in the mud
Re: flex fan or stock clutch fan? [Re: Bigbadtoy] #749078 09/01/06 05:36 AM
L
lookmomnobrains Offline
flex fan will be a constant drain of power and gas. most guys here go electric or stock. if you do go stock spend the full 100 bux and get an oem part.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: flex fan or stock clutch fan? [Re: Bigbadtoy] #749079 09/01/06 06:21 AM
4Crawler Offline
Flex-a-lite makes one model for the Toyota trucks, #165 as I recall. That would be the one to get as it bolts right up in place of the fan shroud. Anything else and you'll have to fool with mounting it somehow. I ran one for a few years then reverted back to the stock fan clutch. Much more reliable and long lasting. I found the original one was getting a little too stiff so got a new one from Toyota and it is a lot looser and has lasted for probably 4 years so far. The one I got from Napa lasted me about a year before it blew up.
Re: flex fan or stock clutch fan? [Re: 4Crawler] #749080 09/01/06 10:17 PM
1
1FastSS Offline
Black Magic 165 here. About 80K on it. I had he mechanical T-stat go out on it and replaced it with an electronic one from NAPA............So far so good............and thanks, it will probibly die next week..... <img src="/forums/images/graemlins/cheers.gif" alt="" />
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: flex fan or stock clutch fan? [Re: 1FastSS] #749081 09/03/06 07:03 PM
half_fast Offline
I went with a electric fan so I can turn it off when in the deep stuff. The only problems Ive had with running the stock fan was water/mud would hit the distributor and cause missfires. Also my k&n filter sitting on top of my Weber was getting totally coated with mud. Now I switch it off as I go in a bog...flip it back on when (if) I get out.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: flex fan or stock clutch fan? [Re: half_fast] #749082 09/06/06 08:08 PM
G
GOI87 Offline
I too use the black magic fan. I found the 160 (I think is the part NO) off of ebay and made the mounts for it. I used some of the angle aluminum looking metal with the holes that you find at any hardware store and a another flat piece with the holes. Had to cut and extend some of the holes a bit but it works great. I too can turn off the fan with a switch. Plus some Go Fast Orange paint really helps with the H.P. <img src="/forums/images/graemlins/notooth.gif" alt="" />
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6134 MB (Peak: 0.6835 MB) Data Comp: Off Server Time: 2026-10-24 08:14:59 UTC
