1988 Trooper 2.6 oil leak #749233 09/02/06 08:55 PM
A
acy76 Offline OP
Well, the oxidized '88 has been leaving quite a puddle wherever it's parked lately. It seems to be coming from the vicinity of the oil filter housing, as the puddle concentrates under that area. I thought it might be the pressure sender, but after a cleaning with engine-brite it shows no signs of a leak there.
Any common causes of leaks in this area? I plan on cleaning from the underside to see whether it might be the pan gasket, although the leak seems to be related to pressure since it stops dripping after a while when the truck is sitting. Could the oil pump be causing the trouble? I seem to recall it's in the same area under the timing cover.
Thanks for any insight.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: 1988 Trooper 2.6 oil leak [Re: acy76] #749234 09/03/06 01:14 AM
JLEMOND Offline
HEY ADRIAN,, IT COULD BE THE CAM SEAL OR THE CRANK SEAL AND THE OIL PUMP SEAL OR ALL OF THEM , AT HI MILAGE THIS IS NOT AT ALL UNCOMMON,,JERRY
Re: 1988 Trooper 2.6 oil leak [Re: JLEMOND] #749235 09/03/06 06:00 PM
A
acy76 Offline OP
you know, i just replaced the cam & crank seals when i replaced the timing belt (this past spring). I didn't even think to replace the oil pump seal. i guess i should take another look under the timing cover.
Re: 1988 Trooper 2.6 oil leak [Re: acy76] #749236 09/08/06 02:56 PM
I
islandracer Offline
I found mine to be the pressure switch, but it only leaked when I revved the motor. It actually was squirting pretty bad when I revved it <img src="/forums/images/graemlins/zombie.gif" alt="" />
B.Y.E. ~ Back Yard Engineering
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6015 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-06-07 07:58:09 UTC
