por-15 ? #749256 09/03/06 12:47 AM
1
1986xtracab Offline OP
how much of this do you guys think I would need to coat my frame?
1986 xtra-cab 22re
stock everything
1991 bed
Re: por-15 ? [Re: 1986xtracab] #749257 09/03/06 01:23 AM
1 pint
Re: por-15 ? #749258 09/03/06 01:56 AM
CJM Offline
I used about 3 pints out of the gallon I purchaced .
inside and out .
83 Trekker SR5
NEW Trekker forum
Re: por-15 ? [Re: CJM] #749259 09/03/06 04:55 AM
1
Thanks for the info, and that is one pretty frame!
1986 xtra-cab 22re
stock everything
1991 bed
Re: por-15 ? [Re: CJM] #749260 09/03/06 03:08 PM
bkg Offline
inside and out .
I think I went through a gallon when I did my frame back in 96 - two coats.
But...
There are better products out there. I've spent about $300 on POR-15 over the years and never once been happy.
Brian K. Gallus
Re: por-15 ? [Re: bkg] #749261 09/03/06 06:51 PM
ToyotaT Offline
But...
Hmm. Any suggestions as to what they might be? I've used three different products and so far, POR-15 is the best - though I have admittedly been let down occasionally. Please share.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: por-15 ? [Re: ToyotaT] #749262 09/03/06 07:14 PM
bkg Offline
I've heard good things about some products from Eastwood. But I think the truth of the matter is that this is an attempt at a shortcut to eliminate rust - And the best solution is to not take the short cut. Just my opinion.
Brian K. Gallus
Re: por-15 ? [Re: bkg] #749263 09/03/06 10:43 PM
jaguarshark Offline
ive used the estwood rust encapsulater,por 15 rip off, and after having the frame sand blasted i brushed on the coating thinned a little with thinner and now it has seaped in so well that whenever i need to grind some paint off the frame it actually clogs the wheel a bit. i used multiple coats though. excellent product.
Re: por-15 ? [Re: jaguarshark] #749264 09/04/06 04:00 PM
yotaman7 Offline
I just got done painting the frame with a product called chassis saver which is very similar to POR-15. It took me about a half a gallon for 2 coats. My frame is an '85 short bed/reg cab. We'll see if this stuff works or not.
Oh yeah, do not shake the can once you've opened it. Trust me <img src="/forums/images/graemlins/lol.gif" alt="" />
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: por-15 ? [Re: CJM] #749265 09/05/06 06:24 AM
muskie Offline
inside and out .
how did you get inside the frame?
93 ext cab. 3.4 in progress
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6290 MB (Peak: 0.7363 MB) Data Comp: Off Server Time: 2026-06-21 11:10:51 UTC
