Page 2 of 3 1 2 3
Re: What plug wires do you guys like? #749278 09/03/06 09:28 PM
kyle-22r Offline
NGK and taylor are what i run.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: What plug wires do you guys like? #749279 09/04/06 02:58 AM
Vonka Offline
Im using MSD and Magnecore on my trucks.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: What plug wires do you guys like? #749280 09/04/06 03:03 AM
J94_4runner Offline
NGK's. Cheap, & factory fit and quality. $50 vs $90 from dealer. I don't run aftermarket wires... they're junk.
www.celicasupra.com
Re: What plug wires do you guys like? [Re: J94_4runner] #749281 09/05/06 03:54 AM
grandeyota Offline
I like the toyota wires. They are sealed up where the boot and the wire meet so water stays out. All the parts store kind I've used in the past didn't have that.
For the $40 they are for my 22re I think they are a great deal.
Fur clog in the sausage grinder
Re: What plug wires do you guys like? #749282 09/05/06 05:17 AM
Brian894X4 Offline
This is one part where you just can't beat OEM factory stuff. They're expensive, but worth it in the long run. Don't buy into the hype from aftermarkets about better spark, more power, bla, bla, bla.
NGK might possibly be the OEM supplier to Toyota, so it's possible that you can just buy the NGK part from any autoparts store and basically get the same thing the dealer sells, but at a cheaper price. But that's only if NGK really is the OEM supplier.
Re: What plug wires do you guys like? [Re: Brian894X4] #749283 09/05/06 02:56 PM
Well, the new plugs helped, but this morning I still had the miss with the spark arcing across the wires. New wires should be here today or tomorrow. It sucks trying to drive to work with 5 cylinders firing. It takes about 5 minutes before it warms up enough for the #5 cylinder to finally start firing and smooth out. It's amazing the original plug wires lasted this long but once they started to go, they went fast!
Re: What plug wires do you guys like? [Re: Brian894X4] #749284 09/05/06 05:05 PM
stock87 Offline
Actually Sumitomo is the OEM suplier (at least that's what's printed on the OEM plug wires).
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: What plug wires do you guys like? [Re: stock87] #749285 09/08/06 03:18 PM
Finally got some new plug wires(Jacobs custom fit, found them locally for $29) and noticed a big difference in the cooler weather. My truck always felt like it was down about 5-10 hp in cooler weather and it may have been the plug wires all along. But now that I have new plugs, new wires, new cap, new rotor, it feels like a new truck. Lots more pep even first thing on a cool morning, no pinging as it gets near 3000 rpm's, no problem towing the boat. The amazing thing is that the old plugs are actually pretty darn clean considering the huge gap, wrong heat range, old wires and distributor cap with rusty terminals. I can probably bump the timing up a little now too.
Re: What plug wires do you guys like? #749286 09/12/06 12:21 AM
JWHnAtl Offline
Where did you find the Jacob's wires for that cheap?
Re: What plug wires do you guys like? [Re: 4xJedi] #749287 09/12/06 01:53 PM
ChrisH Offline
Yes, factory Toyota.
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6366 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-10-22 07:36:37 UTC
