'94 Trooper - Wheel backspacing #749489 09/04/06 04:03 PM
I have a 94 Trooper LS with the factory alloys. By my calcs the backspacing is 5.5" and the lug pattern is 6x5.5. The wheel is stamped with "Offset 38" which I assume is mm.
I'm looking at LT 265/75R/16 tires and a suitable set of rims.
Any suggestions?
Re: '94 Trooper - Wheel backspacing #749490 09/04/06 06:31 PM
88SuperTrooper Offline
Yes they are 6 on 5.5 you are correct on that. As for the back spacing you are also correct, for the OEM or stock wheels you can run a 265-75-16, but Im not sure on the width of that wheel. I think its either a 6 or 7 wide maybe even an 8 wide. I work at a tire shop and I have seen what very narrow wheels do to big wide tires, you'll wear the center of the tire down before any other part of the tire does, It's called crowning. What type of tire are you looking for: Mud Terrain, All Terrain, ect. A 265-75-16 IS a Very common tire size and come in a P-Metric or a LT. LT is what I would recommend, More load bearing and when you get off road you can let air out and still have the tire on the bead with out worrying about losing the bead. PLUS you get Much better puncture resistance from rocks, nails, ect. Basiclly, a 265-75-16 is a 31" tall tire. 285-75-16 is a 33" tall and a 315-75-16 is a 35" tall tire. that is how the P-metric system is by my understanding. 31x10.50x15 is the equivilant of a 265-75-16.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: '94 Trooper - Wheel backspacing [Re: 88SuperTrooper] #749491 09/04/06 08:04 PM
Smiley Offline
Welcome jinmon! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[ -snip- ]
Not to be picky, but a 265/75 is usually considered to be a 32 inch tire.
Strictly speaking, 265/75-16 = 31.6 x 10.43 x 16 (which is pretty-much what my Goodyear MT/Rs measure)
But it really depends on the manufacturer...
My old LT265/75-R16 Cooper Discoverer STTs measured almost exactly 32 x 10.5
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: '94 Trooper - Wheel backspacing [Re: Smiley] #749492 09/05/06 03:19 AM
If you want to get technical Yeah it is LOL, thats what the whole thing about compairing from manufacture to manufacture. but yes, its a 32", stupid metric system sucks when your in this business.... ahahaha. Yep it all depends on who makes the tire like you said. You can take 4 different tire from 4 different manufactures and they will all be different height and width.
31" Big O X/T's
15x8 Eagle 058's
Re: '94 Trooper - Wheel backspacing [Re: 88SuperTrooper] #749493 09/15/06 07:29 AM
RockSolidTrooper Offline
I have LT265/75R16 Dunlops on my 94 trooper and it rides nice.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6657 MB) Data Comp: Off Server Time: 2026-10-27 07:53:31 UTC
