____C a r b u r e t o r s ___? ? ? ! ! !
#749819
09/06/06 04:27 AM
Hey Guys___ Just curios if any of you Toyota (22r engine) guys are running Webber carburetors or just stock. Also what your experience (good or bad), with either carb.and what you recommend and why. You know things like ease of adjustments, rebuiltabilaty, running well, economy etc. Thanks in advance______ BAYRUNNER
Re: ____C a r b u r e t o r s ___? ? ? ! ! !
[Re: bayrunner]
#749820
09/06/06 04:45 AM
I run the weber 38 with hedman header & msd ignition. The setup is simple to tune,jet and trouble free. However, the truck was set up that way when I bought it so all I had to do was tune & jet the weber (once I got it setup, I haven't had to touch it). I get 17mpg winter, 18 mpg summer and 16 mpg offroad, very consistently. For 99% of 4 wheeling I prefer gears over horsepower, so if I was spending the money I'd take gears and a locker over engine mod's anyday. Not to mention, keeping it smog legal which increases your available market area if you ever sell it. Just my 2c.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
[Re: SALMONHEAD]
#749821
09/06/06 06:21 AM
I haven't installed a weber personally, but I own one and know if you search you will find a lot of info. I searched and it eventually convinced me to make the purchase - i got a good condition used one for cheap.
-Scerb
[Re: Scerb]
#749822
09/06/06 01:54 PM
im running a weber 38 on my 84 it runs great, the only problem i had was with the throtle linkage because my factory return sping wouldnt quite return it to the throttle stop. i have a spring on it now but im going to go to a yard and get some linkage that isnt bent to hell. as for the carb i bought, it works great right out of the box. i simply set the idle and drove off.
[Re: SALMONHEAD]
#749823
09/06/06 08:46 PM
I'm running the webber 38 street lethal with LCE header, Jacobs ignition system, and i even got the jet kit for the carb. Right now its running stock jetting, but i havn't played with them yet since i opened up the exhaust with the header and 2.25" exhaust + flowmaster. Havn't had any problems smogging. I like the setup, it has been working well, and once i change the float level it won't load up going up hills anymore.. <img src="/forums/images/graemlins/drunk.gif" alt="" /> I'm gettin 19-21mpg on worn 32's and 5.29's in the diffs. hope this helps <img src="/forums/images/graemlins/shiner.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe Not enough hours in the day to do what i want..... .....and sleep
[Re: SALMONHEAD]
#749824
09/07/06 03:22 PM
I've used several 32/36 carbs and the 38mm. I think the 38mm is complete overkill unless you've done some port work. I noticed no performance difference (slight mileage difference) between the two on a 22r with a mild cam, MSD ignition, header, & full exhaust.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#749825
09/07/06 05:27 PM
that's interesting about the 38mm. I use a 32/36 progressive, but hear from all 38mm users that it'll spin the wheels.
msg - '87 xtracab
[Re: yodta]
#749826
09/12/06 06:45 PM
I have a 32/36 on my dad's truck and a 38mm on mine, world of difference in power. I love my 38mm.
Josh
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
