FRONT PIPE TO MANIFOLD SEAL #749983 09/06/06 07:38 PM
RidingRoughshod Offline OP
I'm having trouble finding the front pipe to manifold seal for my 90 with 2.5L....Seem to have them for jeep but mine..Any ideas where I can get this part other then the local stealer..Or does mine not need that, can't see it not having one
Re: FRONT PIPE TO MANIFOLD SEAL [Re: RidingRoughshod] #749984 09/06/06 09:07 PM
JeePete Offline
Now that you mention it, my 86 CJ's 258 had no gasket. If the manifold has a flare cast as part of it, it probably doesn't use a gasket. A manifold that uses a "doughnut" seal will have a lip that the seal fits around. If you find you need one, a muffler shop is a possible source. I suggest a non franchised one for friendly results. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: FRONT PIPE TO MANIFOLD SEAL [Re: JeePete] #749985 09/06/06 09:16 PM
Based on everything I've read and seen I'm leaning towards that....Sure think it would get a better seal with some kinda gasket..but who am I to question the wisdom of the big wigs at Chysler...Thanks JP <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: FRONT PIPE TO MANIFOLD SEAL [Re: RidingRoughshod] #749986 09/06/06 09:46 PM
JeePete Offline
I should have said the manifold for my CJ has a rounded lip cast at the connection point where the flare on the pipe fits, no gasket required. I just looked at it and verified it, I replaced it with a 4.0 manifold which does use a doughnut, and have the old manifold in the garage. I guess you have not had it apart? Do you have nuts on studs or bolts in the manifold? Can you move the pipe at the manifold? Maybe you just need to tighten it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: FRONT PIPE TO MANIFOLD SEAL [Re: JeePete] #749987 09/07/06 12:32 PM
Mine has the rounded lip and flare so I'm guess I don't need one..My engine sounds like a diesel when standing over it. Sounds great at the tailpipe(mine engine is a 2.5l) it sounded like that before I replaced the exhaust man and exhaust system was just trying to figure out why it sounds like this
Re: FRONT PIPE TO MANIFOLD SEAL [Re: RidingRoughshod] #749988 09/07/06 07:23 PM
JeePete Offline
You should be able to tell if it's leaking or not by close inspection (looking and feeling). with new parts it shouldn't be hard to prevent or fix a leak. My buddies 85 CJ 2.5 sounds like a diesel also. He does have a cracked manifold but the diesel like noise is mostly because it's old and tired. Wear and tear on the entire valve train can cause it. A rattling/light knocking sound you can ignore or you can consider a partial or complete overhaul. I don't know if that has anything to do with your problem though. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: FRONT PIPE TO MANIFOLD SEAL [Re: JeePete] #749989 09/07/06 10:19 PM
JP sounds like my jeep,, she's prolly just worn out...She does run a whole lot better since replacing the exhaust system...I was just concerned that there wasn't a seal for the E/m to exhaust pipe but sounds like this didn't have one(i know there wasn't one when I pulled the old one out) THank again guys
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6201 MB (Peak: 0.6954 MB) Data Comp: Off Server Time: 2026-06-17 07:56:22 UTC
