Whirlpool third?? #750307 09/08/06 03:22 PM
Myota Offline OP
I just swapped in a used rear end(complete) and after driving a couple of hundred miles there is this noise. Same noise that was there previous to the swap.
At 30mph it sounds like a washing machine on the wash portion of the cycle.
This sound is definitely coming from the rear.
Tires are balanced.
Wheels are true.
Nothing is rubbing.
Anyone have any ideas?
Axle bearings?
Third bearings?
Carrier berings?
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: Whirlpool third?? [Re: Myota] #750308 09/08/06 03:57 PM
ErikB Offline
Toyota Moderator
What about the drive shaft- check u-joints and/or slip-yoke wear/lube, straightness, etc.
Also check that the nut holding the t-case flange on is tight. Sometimes they loosen up. Same goes for the pinion flange on the diff.
http://home.4x4wire.com/erik
Re: Whirlpool third?? [Re: ErikB] #750309 09/08/06 04:06 PM
Staceman Offline
Possibly a rear wheel bearing???
Re: Whirlpool third?? [Re: Staceman] #750310 09/08/06 04:11 PM
OOP'S Offline
X2-a lot of times when they are going out they will make a rump, rumb noise.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Whirlpool third?? [Re: OOP'S] #750311 09/08/06 04:35 PM
Myota Offline OP
Exactly the noise I am hearing. I don't think it's driveshaft related as the noise is cycling to slowly.
Re: Whirlpool third?? [Re: Myota] #750312 09/08/06 11:19 PM
G
GOI87 Offline
Driveshaft U-joints will make a clicking noise at low speed. So I would rule out the U-joints.
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust
2003 Toyota Matrix XRS-Injen CAI
Re: Whirlpool third?? [Re: GOI87] #750313 09/09/06 02:45 AM
G
Greg_Canada Offline
Gears/ bearings in the rear diff, we've had it happen more than once...
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6180 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-06-15 10:40:57 UTC
