weber carb help #750560 09/10/06 03:17 AM
L
lu0902 Offline OP
I bought the following weber, model K610 DGEV. Having a hard time with linkage, throttle lever assembly and throttle plate. Can someone help with with this please. A close up pic would really help of the above. I need to see how to assemble these parts and. I am not even sure it came with the right thorttle lever assembly.
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: weber carb help [Re: lu0902] #750561 09/10/06 03:35 AM
Homebrewer Offline
This is the kit that I just installed. Is yours the same one?
1989 Montero LS
1997 Jeep Wrangler
Re: weber carb help [Re: Homebrewer] #750562 09/10/06 04:20 AM
L
lu0902 Offline OP
No cable adaptor, no return spring plate, throttle linkage looks a bit diffrent. Is yours a manual or automatic
Re: weber carb help [Re: lu0902] #750563 09/10/06 04:41 AM
L
lu0902 Offline OP
Found the problem this fools mailed me the wrong carb. I ordered a DGEV they send me a DGAV, pulls the wrong way. Danmmmmm <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: weber carb help [Re: lu0902] #750564 09/10/06 04:43 AM
Homebrewer Offline
Mine's a manual. IIRC, you have to rig something up for the throttle kickdown cable on an auto.
I think that some people have installed the reverse pull successfully, although I'm not sure how they did it...
1989 Montero LS
1997 Jeep Wrangler
Re: weber carb help [Re: Homebrewer] #750565 09/10/06 05:01 AM
L
lu0902 Offline OP
Thank you for your help. When I get the right one on I will be able to install it very quicklly thanks to you. As far as they go they better get me the right carb. <img src="/forums/images/graemlins/angry.gif" alt="" /> So you say you did not have to use the lever plate. Is it assential. And one more thing what did you connect the little blue wire to.
Re: weber carb help [Re: lu0902] #750566 09/10/06 05:06 AM
Homebrewer Offline
Yeah, that lever plate just moves the throttle cable to the other side of the carb. I'm not sure why it's included in the kit as it wasn't needed here. It would be needed for the reverse pull version though...
As far as the blue wire goes, I didn't use it. I just found a +12v line that went to the old carb and used it to hook to the choke. It was one of the red wires.
1989 Montero LS
1997 Jeep Wrangler
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6153 MB (Peak: 0.6933 MB) Data Comp: Off Server Time: 2026-06-07 02:25:47 UTC
