3.0 Throttlebody on a 22RE? #750936 09/11/06 06:25 PM
TOY4ICK Offline OP
Is anyone using a 3.0 throttle body and TPS on their 22RE? I have increased size of the valves (thanks EB) and the exhaust and was wondering if a bigger throttle body would be beneficial. Do I also need a different (bigger) MAF sensor (maybe from an older Supra)? I built an adapter to fit a spare 3.0 throttle body onto a 22RE intake plenum. Unfortunately,, I only have older style plenums which tilt down in the front and do not allow enough clearance between the linkage and the fuel rails. Is it worth finding a later 22RE plenum for this project? I would like to know before spending any actual money. <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks,
Isaac
'86 4Runner SR5 - 22R-EB with V-6 Throttlebody, 2" 4Crawler B.L., Ball Joint Spacers, Rock SliderZ, TJ Coils, 5.29's, Rear Locker, 33" Duratracs
Re: 3.0 Throttlebody on a 22RE? [Re: TOY4ICK] #750937 09/11/06 07:19 PM
mosk Offline
You can use a 60mm Supra TB. I am not sure of the year, but probably from the 7M series. Several folks on the 22RTE mailing list have gone this route with good success. This will allow you to use the stock TPS, and I think the linkage is fairly easy to adapt, but I don't know for sure. All things being equal, a bigger TB on a mildly modified normally aspirated motor may be good for 5 peak hp, with other gains across the power band. Do not expect this one mod to make the motor into a rocket ship, but it can help if the TB is restrictive.
The stock AFM is easily good to 160 hp. Swapping this out -- typically to one from a 1982 5MGE Supra, which is plug-and-play -- opens a big can of worms and is not recommended unless you are making an honest 160+ at the rear wheels. Note that ONLY the 1982 Supra AFM is plug-and-play; for all other years, the Supra's AFM signal voltage is the inverse of what the 22RE needs to see.
Oh, and yeah, you if you're going to go to this trouble you should also use a late model plenum, which will improve the air pathway and eliminate the air control valve, which tends to leak with age.
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: 3.0 Throttlebody on a 22RE? [Re: TOY4ICK] #750938 09/11/06 11:13 PM
willzrunna96 Offline
i picked up the new style plenum and a yard for 10 bucks. i actually have 2 spares just for the hell of it so id invest it if you can find one
Re: 3.0 Throttlebody on a 22RE? [Re: willzrunna96] #750939 09/12/06 12:13 AM
dcg9381 Offline
I'd buy them all day long at $20.... Great deal.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6044 MB (Peak: 0.6614 MB) Data Comp: Off Server Time: 2026-06-07 04:38:14 UTC
